Firestone ride rite air springs
Discussion in 'Suspension' started by mgtundra, Jun 17, 2018.
  1. Jun 17, 2018 at 5:12 PM
    mgtundra
    mgtundra [OP] New Member
    Joplin mo,
    2015 mg tundra
    6112 bilstein coilovers,5160 remote resivor,camburg upper arm,sway bar,Trd pro skid plate,Trd pro mg grille,high flow air intake
    Question: I plan on putting these on my 2015 dc, was wondering if on your truck with no air in bags if it would raise the height of the rear of the truck,I’ve run 6122/5160 Holsteins which leveled truck just the way I want and don’t want any height due to air bags.
  2. Jun 17, 2018 at 5:13 PM
    mgtundra
    Joplin mo,
    2015 mg tundra
    That’s blistein s damm auto correct
  3. Jun 17, 2018 at 5:53 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    I had these on a Tacoma. Minimum suggested air pressure is 5psi, they say don't run them at 0. At 5psi there was no lift in the rear at 40psi it could jack up the rear a couple inches probably. Even at 5psi the truck rode a bit stiffer, but those Tacoma leaf springs were so bad and weak. These worked wonders on that truck.
  4. Jun 17, 2018 at 6:13 PM
    mgtundra
    Joplin mo,
    2015 mg tundra
    Cool thanks for the info, plan on getting travel trailer in the future wanted to get something to help out the ride and take care of any squat that I might have
  5. Jun 17, 2018 at 6:56 PM
    Pudge
    CT
    The best thing you can do it get a weight distribution hitch. You can also look into helwig helper springs, sumo springs, superbumps, in addition to air bags. I believe airbags are the most likely from the above choices, to affect your ride quality when you aren't towing or hauling.
  6. Jun 17, 2018 at 8:07 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    This^^^^
    Especially if you're planning to haul anything.
    I have bags on my truck, accompanied with some Icons. They certainly help the ride, especially if there's a load in the bed. I don't think i've ever had more than 15 psi in them.
    If you have any lift/leveling to your ride and you're going to haul (a travel trailer) I would highly recommend a weight dist. hitch, like the Equal-i-zer.
    https://www.equalizerhitch.com/how-equalizer-works
    Pudge[QUOTED] likes this.
  7. Jun 17, 2018 at 8:57 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    This X2. I have a pro and it sagged with my car hauler. After looking at all the helper spring options, I learned about the WDH and it's the best choice for what you seem to be looking to do. Also has other benefits, like sway control and the ability to back up with it attached.
    GAknight[QUOTED] likes this.
  8. Jun 17, 2018 at 9:59 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I would like pictures of the Holsteins with air bags
    JoshuaA likes this.
  9. Jun 17, 2018 at 11:01 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Installed and used properly, air bags will not add any height when empty. When loaded, they should only be aired up enough to offset any squat. They are not intended for lifting.
    Coachbuilder1 and GAknight like this.
  10. Jun 19, 2018 at 7:57 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Dont mean to hijack your thread, but will airbags help when my bed is loaded?, we went camping and the rear was pretty low..I do plan to tow a trailer in the future but for now just load on the bed.. thanks.
    Pudge likes this.
  11. Jun 19, 2018 at 8:31 AM
    Pudge
    CT
    Yes they would help a lot. So would helper sprigs and maybe even different bump stops
    saybng[QUOTED] likes this.
  12. Jun 19, 2018 at 9:13 AM
    saybng
    Gary
    Ventura CA
    Any recommendations on helped springs etc...thank u.
  13. Jun 19, 2018 at 11:21 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    I would add a leaf if I was under constant bed load (eg; owned a topper, regularly hauled), airbags if I towed all the time, or Sumos/Timbrens if I occasionally towed. S/T’s have a floating space under the frame when not towing so don’t affect the day-to-day ride unless you hit them when going over bumps and potholes.
    Whichever system and when towing, I’d use a WDH rated for the tongue weight.
  14. Jun 19, 2018 at 11:59 AM
    saybng
    Gary
    Ventura CA
    Does adding a leaf lift the rear?
