Firestone Airbag Question
Discussion in '2.5 Gen Tundras (2014-2021)' started by JeffMac, Nov 3, 2021.
  1. Nov 3, 2021 at 10:18 PM
    JeffMac
    JeffMac [OP] 2 Words, 1 Finger
    Jeff
    South Florida
    2015 Black Tundra OVTUNE
    Suspension: Bilstein 6150 Front Max Setting CB Shim 2x Driver 1x Passenger Bilstein 5160 Rear CB +3 Shackles Firestone Airbags w/ Daystar Craddles Engine: OVTUNE - 87 w/ Torque Modifier SABM w/ K&N Filter TB Coolant Bypass Fumoto Drain Plug Wheels/Tires: ProComp Bandidos 0mm Offset Nitto Exo Grappler AWT 285/70/18 Exterior: TRD Pro Grille Spyder Headlights/Taillights Ecoological Bumpershellz LED everything Tinted windows Bakflip MX4 Tonneau Cover K-Source Tow Mirrors Interior: Pioneer AVH-W4500NEX Radio 2x 10” Pioneer Subwoofers 1200W Pioneer Mono Amp 2000W Pioneer 4 Channel Amp
    I have a 2015 Crewmax. Bilstein 6112 top setting w/ 2 driver 1 passenger shim. Rear Bistein 5160 w/ CB +3 shackle.
    I’m purchasing some Firestone 2445 and was wondering if the Daystar cradles or Coach Builder Airbag spacer kit is better for my setup.
    https://smile.amazon.com/dp/B0084ROJBM
    https://shop-coachbuilder.myshopify...ilder-airbag-spacer-kit-actual-thickness-1-50
  2. Nov 4, 2021 at 12:24 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I had this exact same setup for a while. The plus 3 shackle, in my opinion is unnecessary with airbags. You don't need the rake if you have airbags as you can level with the bags. With the plus 3, the air bag manufacturer recommends that you run spacers (or brackets) due to the stretch caused by the large gap between the axle and the frame. I was running a 2 inch spacer and basically it didn't allow the rear end to level out. I wasn't able to get rid of the rake in the truck while towing my travel trailer. The truck was always riding ass end high due to the large rake to begin with. When I put a load on the truck the rake would calm down but as soon as I filled the airbags the rake would come back. I switched to the plus 2 coachbuilder and I'm much happier with the setup. The truck is pretty much level and I have more down travel due to being able to remove the spacer. I added the daystar cradles and love them. Now the ride is a lot softer due to the fact that during everyday driving the airbag's are not touching the axle and stiffening up the ride. Now I can load my trailer, and have the airbags with some pressure and the truck rides perfectly level.
  3. Nov 4, 2021 at 12:26 AM
    Tundyfundy
    Bay Area, CA
    JeffMac[OP] and NewImprovedRon like this.
  4. Nov 4, 2021 at 12:31 AM
    Tundyfundy
    Bay Area, CA
    Further more it looks like (from the guide I posted) that there are specific "lift brackets" designed to serve the function of spacers for the 2445 kit. ( See bottom of guide page)
    Remember that the plus 3 shackle gives 1.75" of lift, So I'd assume you would use the 2" lift brackets.
    JeffMac[OP] likes this.
  5. Nov 4, 2021 at 9:02 AM
    JeffMac
    Jeff
    South Florida
    Thanks for all the great info. I think I’ll start with the Daystar cradles and see how those work. I’ll swap to the CB ones that are 1.5” if there is an issue.
    I never tow just the occasional pallet of material in the bed for projects. I currently have the black sumos but too much bro lean for my liking.
  6. Nov 4, 2021 at 9:41 AM
    ErikTRDTUNDRA
    ErikTRDTUNDRA New Member
    Erik
    2018 Tundra crewmax 1794
    +1 for daystar cradles
    JeffMac[QUOTED][OP] and Krezz like this.
  7. Nov 4, 2021 at 3:27 PM
    JeffMac
    Jeff
    South Florida
    All ordered. Hoping to have everything by this weekend.
  8. Nov 4, 2021 at 3:42 PM
    +2 for Daystar cradles.
  9. Nov 5, 2021 at 12:34 AM
    diablodalton
    diablodalton New Member
    Dalton
    Oregon
    2021 Crewmax Platinum MGM
    8" Ready Lift, SPC UCA's., Bilstein B8 8125, Amp Steps, 37/12.5R 20 Cooper STT PRO, On order: Valhalla Armor, Dirty Deeds Exhaust
    I ran daystars on my lifted taco and loved them! Ordering them now for my Tundra!
  10. Nov 5, 2021 at 3:23 PM
    DanTundra
    DanTundra Danny
    Wilmington, NC
    2015 Ribbon Blue Tundra SR5 4x4
    TRD sway bar, airbag kit, Diamondback HD, LED headlights, Pedal Commander, Bilsteins 6112's up front with shims (2.5 inch lift), 5160s in the rear with CB +2 shackles (1.5 inch lift), Falken Wildpeak AT3W 285/75/18, TRD Pro Grill insert, MattGecko under hood and bed light kit,
    I have CB +2 shackles with airbags and didn't need the airbag spacers. I bought the truck used and the former owner installed Goodyear airbags on the truck, so I bought the spacers, but didn't need them.
    Looking at purchasing the daystars, but I haven't pulled the trigger yet.
  11. Nov 8, 2021 at 12:35 PM
    JeffMac
    Jeff
    South Florida
    Okay all installed. CB +3 shackles work perfectly with the Daystar Cradles. Glad I didn’t opt for the spacers.
    The Dude and diablodalton like this.
  12. Nov 8, 2021 at 2:10 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    I have Firestone airbags, Daystar cradles, Coachbuilder +1 and an Icon add a leaf.
    I ordered airbag spacers. Did not need or use them. I could see how they could be useful without the cradles but not necessary with.
    So if anyone in Canada wants a deal on spacers let me know!
  13. Nov 8, 2021 at 2:23 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Looks good. I’m a bit surprised your airbag is making contact with the cradle with the +3 shackle, or do you have weight in the bed?
    JeffMac[QUOTED][OP] likes this.
  14. Nov 8, 2021 at 3:37 PM
    JeffMac
    Jeff
    South Florida
    I do have some weight in my bed. It’s inside the cradle but hovering about an inch above the bottom.
  15. Nov 8, 2021 at 3:45 PM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Good to know. I have the +2 shackles on order and my daystar cradles just arrived. I’ve been running the Firestones for about a year now without the cradles. I’m hoping my +2 shackles will keep my bags off the cradles with an empty bed as I’m hoping to improve my ride with the shackles. Keeping just the recommended 5 lbs minimum in my bags definitely stiffened up the rear end.
  16. Nov 8, 2021 at 5:29 PM
    JeffMac
    Jeff
    South Florida
    Mine rides exactly the same as before which is perfect. I can see why because you’re constantly hitting a bump stop basically. I’m sure you’ll be happy.
    Squeaky[QUOTED] likes this.
  17. Nov 8, 2021 at 5:40 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
  18. Nov 8, 2021 at 6:36 PM
    JeffMac
    Jeff
    South Florida
  19. Nov 8, 2021 at 9:50 PM
    Tundyfundy
    Bay Area, CA
    looks like he has some pressure in the bags
  20. Mar 16, 2022 at 11:38 AM
    SeanO86
    SeanO86 Live Slow. Die Whenever.
    2018 SR5 Tundra TRD Off Road - Cement
    Fox 2.5 w/Resis +1 CB Shackles SPC UCA Alcan 750lb springs - +1" lift 3" Front : 1.65" Rear to level Toyo ATII 35s Icon Six Speed +25 offset Wheelers Superbumps Chrome delete ARE Z Topper w/ Thule rails Pinsu Topper rack RTT - Tepui Autana Ruggedized 3
    I'm thinking about going with this this Firestone + Daystar config on my rig, how does this setup perform with full upward travel? even at 5psi wouldn't there be concerns of pinch (compression) tearing on the bags?
    I've got the Fox 2.5 rear shocks and alcan springs, so I've got a decent amount of suspension travel back there on trails. sometimes my 35" tires rub the wheel well on moderate trails that require some crawling. this is my main concern.
  21. Mar 16, 2022 at 8:58 PM
    diablodalton
    Dalton
    Oregon
    I can’t speak to the Tundra set up but I had the same set up on my Tacoma and had zero issues. I did a ton of off roading and crawling in that truck fully loaded with a canopy, 2.5 shocks, decked system, etc. I have the same system for my tundra and will be installing it with complete confidence soon!
    Chowdah and SeanO86 like this.
  22. Mar 20, 2022 at 5:03 PM
    Chowdah
    Chowdah New Member
    Oceanside, CA
    2020 MBM Tundra TRD Pro
    A.R.E. Truck Cap HD Method Grid Wheels Mickey Thompson Baja ATZP3s
    I’m about to do this exact thing to my truck. +3 shackles from the group buy and the airbags and Daystar cradles.
    SprinterAE86 likes this.
