Firestone Airbag Kit Clone???
Discussion in 'Suspension' started by kparrow, Aug 24, 2020.
  1. Aug 24, 2020 at 6:36 PM
    kparrow
    kparrow [OP] New Member
    Kevin
    Nampa, ID
    Found this kit from Torque....seems to be a Firestone kit clone and it’s $100 less expensive than the Firestone kit. Anyone try it out yet for feedback? It’s shipped from Amazon so I figure if it sucks....I could return it but looks like the same exact kit to me.....
    TORQUE Heavy Duty Air Spring Helper Suspension Kit for 2007-2019 Toyota Tundra 2WD 4WD (Replaces Firestone W217602445 Ride-Rite 2445) TR2445 https://www.amazon.com/dp/B07W7MDKL6/ref=cm_sw_r_cp_api_i_qPgrFb3NJET7H
    bgdv1, jeremyd and Joejosekemp like this.
  2. Aug 24, 2020 at 7:13 PM
    Razorwyre
    Razorwyre New Member
    2018 Tundra Platinum
    I love a good deal, but at that price difference, and the PITA to remove if I don't like it, I am going with Firestone and be done.
    runCMD, Tundyfundy and kparrow[OP] like this.
  3. Aug 24, 2020 at 8:15 PM
    pickeledpigsfeet
    pickeledpigsfeet New Member
    Sierra Foothills, Ca
    2019 Tundra/14 FJ/ 90 SASed xcab
    Kings & Icons
    I am running Summit Racing’s airbag kit which is the Torque kit you are showing. I had fiestones on my 08 and build quality is close enough that I cant tell the difference between the airbags. I have 5k and a cross country trip on the Summit/Torque kit with no issues while carrying a 1k lb cabover camper.
    M3Tundra-JK, jeremyd and kparrow[OP] like this.
  4. Aug 24, 2020 at 8:18 PM
    pickeledpigsfeet
    Kings & Icons
    kparrow[OP] likes this.
  5. Aug 24, 2020 at 8:24 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    50% chance they come out of the same factory as firestone
  6. Aug 30, 2020 at 7:55 PM
    kparrow
    Kevin
    Nampa, ID
    So y’all think I should give them a shot?
  7. Aug 30, 2020 at 8:34 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    Looks exactly like my Firestone kit, I say go for it !
  8. Jan 18, 2023 at 2:38 PM
    HumbuckerBob
    HumbuckerBob New Member
    Bob
    2020 Tundra SR5 TRD 4x4 Off Road
    kparrow, what did you decide? Did you go with the 'Torque' bags? I am about to "Add to Cart" myself. The reviews look good with the exception of some of the bolts missing or wrong but... the customer service seems to be legit with making things right quickly!
  9. Jan 22, 2023 at 7:19 AM
    bgdv1
    bgdv1 New Member
    Dave
    Butler,Pa
    2019 Limited CMSB
    I saw these when searching for a kit, very interested in seeing how they work out for you.
  10. Jan 22, 2023 at 7:25 AM
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    I've been running this kit for a year or two with no issues. The only problem I has is they sent the wrong airbags in the kit, but I called them and they shipped the correct ones that day. I recommend checking that you got all the correct parts before you go tearing into your truck just in case.
  11. Jan 22, 2023 at 7:56 AM
    sask3m
    sask3m New Member
    Alberta
    Black 2019 SR5
    The bolts that come with Firestones kit are absolute chinese garbage anyways.
  12. Jan 22, 2023 at 9:34 AM
    HumbuckerBob
    Bob
    Received the Torque bags yesterday. Did an inventory of all the items. All good with the exception of a broken zip Tie (no Biggie) and they state in the directions that there should be two (2) fuel pump extension brackets but only came with one. Again no biggie...just a typo because it seems you only need one for install. Quality wise they seem great...no different than other products I have had in the past. I'll update after install!
  13. Jan 24, 2023 at 9:13 PM
    kparrow
    Kevin
    Nampa, ID
    I ended up going with a Firestone kit. NIB local for $200, couldn’t pass it up
    bgdv1[QUOTED] likes this.
  14. Jan 25, 2023 at 4:25 AM
    msmmce1
    msmmce1 New Member
    I have that exact one, been on for 3 years, tow a 7k lb travel trailer and it works perfectly.
  15. Aug 18, 2023 at 8:41 PM
    IowaGuy
    IowaGuy New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    1. Do you need to remove the wheels to install
    2. There is a set that comes with Daystar cups - are those needed?
    3. A review mentioned to not cut the bump stops all they way down due to the center bolt?
  16. Aug 18, 2023 at 8:49 PM
    helidave
    flagstaff
    2015 DC 4x4
    1. no
    2. highly recommended for articulation and preventing damage to the airbags
    3. Cut them off so they're level with the top of the u-bolts or slightly lower. Or you can use a chisel and pop the whole rubber piece off the bumpstop mounting plate
    IowaGuy likes this.
  17. Aug 19, 2023 at 6:27 PM
    IowaGuy
    IowaGuy New Member
    In Process
    Tell me more about popping off the rubber piece with a chisel. Is there a center stud in there I need to break with a cold chisel. Or would I pry up from the bottom of the rubber piece and pop it off the stud.
  18. Aug 19, 2023 at 8:40 PM
    helidave
    flagstaff
    2015 DC 4x4
    If I remember correctly, you can use the chisel to separate the rubber bumpstop from the metal base plate and it basically pops off. Just work around the stud in the center. You shouldn't need to chisel through any metal.
