Firestone air bags
Discussion in '2.5 Gen Tundras (2014-2021)' started by 34577dgreen, Oct 11, 2021.
  1. Oct 11, 2021 at 3:57 PM
    34577dgreen
    34577dgreen [OP] New Member
    Had these installed earlier this summer, noticed the bags are making contact with the plates at 30 PSI- I was gonna drop down the 10psi for the winter…
  2. Oct 11, 2021 at 4:05 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Are your bags bolted down top and bottom?
    And I run 5 psi unloaded in the winter.
    snivilous likes this.
  3. Oct 11, 2021 at 4:08 PM
    GeoJoe
    GeoJoe 2018 Tundra SR 4x4 5.7L Looooooooong Bed
    3/1 lift on 20" OZs with KOs, LED fogs, steps and a handle
    Same here... very low year round without anything in it.
  4. Oct 11, 2021 at 4:08 PM
    34577dgreen
    Yes bolted down… I have a decked box and a cap so I guess I’m considered still somewhat loaded… I noticed even at 10psi though the truck is being lifted by the bags…. I was doing some back road driving with two canoes on yesterday at 30 psi, I was dry fitting a winter rim and noticed they had been making contact and thought was odd…
  5. Oct 12, 2021 at 12:01 PM
    2mchfun
    Dump the bags, get a Roadmaster Active Suspension kit.
    HulkSmurf14 likes this.
  6. Oct 12, 2021 at 12:04 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    I completely disconnect mine if I have no weight (or at least run 5psi if you don't want to run them empty). Any pressure makes the ride total ass on mine, let alone at 30psi! That's like towing a heavy trailer level for me.
  7. Oct 12, 2021 at 3:48 PM
    mountainpete
    Same here - 30 psi is super rare. I know some folks that have 45+ in there but to me it's just a pogo stick.
    Since I have Daystar cradles I was actually thinking about creating a vacuum and sucking the airbags up high over the winter. But as a started researching it I learned that Firestone doesn't recommend anything less than 5 psi in extreme cold (-20C or colder) to prevent cracking.
    GeoJoe likes this.
  8. Oct 12, 2021 at 6:28 PM
    GeoJoe
    This is good to know.
  9. Oct 14, 2021 at 1:27 PM
    design311
    design311 Smoke Eater
    Brad
    Bentonville, AR
    2018 Tundra Inferno TSS
    Looks to me like you need to loosen the bottom bolt and adjust the bag. Your bags should be more upright, not at an angle like that. That bottom bracket is slotted which allows for some adjustment. I have the same kit on my truck.
    Seaflea likes this.
