Firestone air bags
Discussion in 'Suspension' started by FLTrucks, Feb 25, 2017.
  1. Feb 25, 2017 at 11:01 AM
    FLTrucks
    FLTrucks [OP] New Member
    For those of you that have purchased the Firestone airbags i have a question for the lift trucks. I was wondering if there are a direct fit our is a spacer needed to install the correctly? Going to be making a purchase on them just want to get everything su once for the install. BTW i have the bullet proof 12" kit on my truck.
  2. Feb 25, 2017 at 11:04 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Is it a block and add a leaf in the rear?
  3. Feb 25, 2017 at 11:09 AM
    FLTrucks
    Added atlas springs and shackles
  4. Feb 25, 2017 at 4:54 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    With a 12" lift you'll need lift spacers for your airbags.
    NewImprovedRon likes this.
  5. Feb 26, 2017 at 9:53 PM
    FLTrucks
    Thats what i figured just was not sure. I seen they sell spacers for them but wasn't sure the size needed. Was hoping someone that has bulletproof kit would be able to help out with the size of spacer needed. Didn't want to make an order for the air bags then another order for the spacer after measuring for the spacer but I guess that may be the best way.
  6. Feb 27, 2017 at 8:38 AM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Yeah. I guess it depends on the lift and how far away your springs end up being from the frame. Twer it me, I'd get someone to measure from the top of the leafs to the nearest point on the frame, with a stock tundra. Then do the same on your lifted, and deduct the difference. That would tell you the size of the spacer needed.
  7. Feb 27, 2017 at 12:52 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I would call Firestone direct and look at using a larger bag. They are easy people to deal with. Just ask for Tech support. 800-888-0650
    FLTrucks[OP] likes this.
  8. Mar 1, 2017 at 1:42 AM
    FLTrucks
    They didn't want to help me. Was stating for safety reason they didn't want to suggest anything. Maybe i just got the wrong person to ask for help
  9. Mar 1, 2017 at 6:32 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If someone with a stock Tundra Pro does measure this, please post the measurement here, thanks!
