Firestone 2245 Airbag install
Discussion in '1st Gen Tundras (2000-2006)' started by Brewster, Nov 26, 2020.
  1. Nov 26, 2020 at 11:26 AM
    Brewster
    Brewster [OP] New Member
    G
    2006 AC Tundra
    Hey guys!
    I’m finally getting around to installing my Firestone airbags with the Daystar cradles, and I’m running into some questions.
    When they’re positioned as spec’d from Firestone, the bag rubs on the bump stop joist, and when they’re spaced appropriately they’re too far for the U-bolt tie to ‘hold’ on. Anyone done a similar install?
    For reference, I have an 06 TRD AC. Thanks in advance, and happy Thanksgiving!
    brewster
  2. Nov 26, 2020 at 11:44 AM
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
  3. Nov 26, 2020 at 11:46 AM
    Did you remove the bump stops or ct them flush?
  4. Nov 26, 2020 at 11:51 AM
    Gmillz85
    Gmillz85 Ski Bum Extraordinaire
    greg
    2004 Salsa Red AC 4x4 Pro Edition
    She's a Pro
    Take the Bumpstops out. Your bags are technically now your bump stops.
  5. Nov 26, 2020 at 11:53 AM
    Maadcaap
    2019 Trd Pro
    275/70/18 KO2
    Here is more info from Firestone
  6. Nov 26, 2020 at 11:57 AM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Now I know what a 'jounce bracket' is and I feel better for it.
    Happy Thanksgiving, guys!
    Leo's first, CodyP and FrenchToasty like this.
  7. Nov 26, 2020 at 12:29 PM
    Brewster
    G
    2006 AC Tundra
    Thanks guys.
    I was under the impression that using these as your sole bump stop was no bueno? the instructions/user pics also show them mounted fore of the bumps.
    no matter how it’s angled, even with more than 1/2” of space, they ride the jounce a bit. Might just get the gas axe out and do a little snipping.
    Thanks again!
  8. Nov 27, 2020 at 6:42 AM
    Professional Hand Model
    Hand Protectors
    Seems these bags like to tear or get punctured from readings of others in the past. Sounds like you have some skills. Post up pics man!
  9. Nov 27, 2020 at 9:32 AM
    Gmillz85
    greg
    She's a Pro
    Weird you have to grind. Here's mine, mounted flush with the jounce bracket and daystar cradles underneath. I have an inch of clearance between the bag and the bracket.
  10. Nov 27, 2020 at 3:26 PM
    Brewster
    G
    2006 AC Tundra
    I ended up pushing it farther up the leaf, and just cranking on the 1/2” spacer.
    The 90 1/4” fitting for the top of the bags were junk though, so I ended up swapping them for some true compression fittings.
    Thanks for the pics @Gmillz85, I rushed it without thinking and had to try to scramble my mistakes ha.
    We’re Baja bound within the week!
    Leo's first and Gmillz85 like this.
  11. Nov 27, 2020 at 3:46 PM
    Gmillz85
    greg
    She's a Pro
    My 90 fittings were finicky. I was losing pressure in my passenger side bag until I figured out I could crank it down another two rotations (didn't want to overtighten at first ya know?!). They have been perfect since. You'll love the ride, it was night and day difference.
    At the time I did the bags I also did a Toytec AAL so maybe I had better luck getting everything positioned while it was all loosey goosey. Great to see you got it all settled!
