F'ing Bushwacker Fender Flares!
Discussion in '2.5 Gen Tundras (2014-2021)' started by Buster1, Feb 16, 2020.
  1. Feb 16, 2020 at 5:59 PM
    Buster1
    Buster1 [OP] New Member
    Oregon
    2019 Cavalry Blue Limited TRD Off Road Double Cab
    Washed my truck today and noticed every one of the flares had the weather stripping coming loose. Three of them it was pushed in and the rear driver side by the fuel cap was just flopping in the wind.
    Pulled them off thinking I'd order new weather strip and the paint is f#$&ed where that shit sat! Truck doesn't even have 5k miles on it!
    Avoid them like the plague!..:mad:
    Boerseun likes this.
  2. Feb 16, 2020 at 6:02 PM
    18" TRD Off Road Wheels
    That's a bummer. I've not done flares for this reason. If I ever to them I will be puttin' something there to protect the paint. Might just do bedliner on the lower portion of the truck and go up over the feners with it. Then the flares can't touch the paint.
    Tundyfundy, Mountun Goat and 15whtrd like this.
  3. Feb 16, 2020 at 6:04 PM
    cctxquicksand
    cctxquicksand IG - TRDistheWrd
    Damn, that sucks. Sorry to hear op. I have some eBay specials that the welting was doing the same just about every day . I found some on Amazon that had 3m adhesive strips, when I installed them I also put electrical tape as a second layer of adhesive on the inside. I have not had an issue in about three weeks. I feel your pain
  4. Feb 16, 2020 at 6:06 PM
    plinyyounger
    plinyyounger New Member
    Ken
    Idaho
    2025 Tundra limited
    3-2 lift, KO3’s, Fuel wheels, tint.
    I totally agree with the OP, they can do a lot of damage. They look good, but they cause paint issues and rust.
    Tundyfundy and GODZILLA like this.
  5. Feb 16, 2020 at 6:09 PM
    Buster1
    Oregon
    And in case you're wondering why I hadn't noticed the strip by the fuel cap coming loose before now, we can't pump our own fuel in this commie ran state!
  6. Feb 16, 2020 at 6:24 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    That sucks, sorry @Buster1 . Thanks for the heads up.
    GODZILLA likes this.
  7. Feb 16, 2020 at 6:30 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Got any Pictures of the paint? I’ve been tossing flares up for sometime but maybe I won’t now...
  8. Feb 16, 2020 at 6:32 PM
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    Dang that sucks! I heard about this issue on flares so I try to avoid them
  9. Feb 16, 2020 at 6:33 PM
    15whtrd
    15whtrd Mr. Blonde
    I suggest anyone that wants to put them on and is worried about chafe, put some clear 3M protectant tape down. It’s basically the same stuff they use for front end rock chip protection.
  10. Feb 16, 2020 at 6:35 PM
    aussieaarons
    Do you cut the 3m to the same shape as the flare? Like a half moon?
  11. Feb 16, 2020 at 6:37 PM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    yup! They eventually will rub through the paint. Found out just in time before it rubbed through the clear coat. Should be able to buff out. Going to install them back and add some clear 3m protection film where the rubber contacts the paint.
    15whtrd and GODZILLA like this.
  12. Feb 16, 2020 at 6:39 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    you beat me to the punch
    Tundyfundy and 15whtrd[QUOTED] like this.
  13. Feb 16, 2020 at 6:52 PM
    ZPMAN
    Minnesota
    15whtrd likes this.
  14. Feb 16, 2020 at 6:56 PM
    15whtrd
    15whtrd Mr. Blonde
    I don’t have fender flares but what I would do is, have the fender flares in my hand and trace the contact patch onto the 3M. Cut it just slightly bigger than where the flare rests. The margin would be up to you. If the roll of tape isn’t wide enough to do the entire flare, You can do it in sections and just piece it together. There may be a better way, but that’s what I would do. That’s also got me thinking if you were to spray the area with plasti dip. Just tape off around your fender flares leaving maybe an 8th inch of gap between the tape and the fender flare, remove the flare and put a whole bunch of coats on the paint where the fender flare would be resting.
    Mountun Goat and GODZILLA like this.
  15. Feb 16, 2020 at 7:12 PM
  16. Feb 16, 2020 at 7:27 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
  17. Feb 16, 2020 at 8:13 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    I have the bushwhacker flares and the tape is a joke. They never set right from day one and the “adhesion” to the flares is no good. It’s super thin and rolls around all over the place. You get it on and a few days later notice gaps or roll-in sections. Grrrr... Think after reading this, I will pull mine pending a real solution. I thought of contacting the company, but what will they do? Send another roll that still won’t adhere to the flares.
  18. Feb 16, 2020 at 8:19 PM
    ZPMAN
    Minnesota
    Also remember that when installing flairs that they will collect all kinds of dirt/salt if not sealed, on my rears (box sides are expensive) I applied some grease on the flair and black silicone to the inner quarter for a tight seal. The grease will not let the silicone stick to flair.
    Mountun Goat likes this.
  19. Feb 16, 2020 at 8:27 PM
    TokerJoker
    TokerJoker ΜΟΛΩΝ ΛΑΒΕ
    Travis
    Nowhere, Specific
    2014 Black SR5 4.6 Dbl Cab
    None.....yet
  20. Feb 16, 2020 at 9:06 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Sorry to hear about the paint that’s a real bummer. I would put some of the paint protective film under the flares where they meet the body.
  21. Feb 16, 2020 at 9:15 PM
    Buster1
    Oregon
    I'm going to try and buff it out and leave them off.
  22. Feb 16, 2020 at 9:26 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    I think they look like shit, and cause damage.
    Double fucking no thanks.
    When I’m looking at used vehicles, as soon as I see them in the pics, no matter what the “deal” might be, I click right on past and don’t even consider the vehicle.
    For this exact reason.
    Removal = $3,000 paint job.
    plinyyounger and Mountun Goat like this.
  23. Feb 20, 2020 at 10:39 PM
    Boosted4runner
    WA
    :D
    @plinyyounger
    I made my way south this winter, and I plan on taking half a suitcase back with me. (Visiting Napa)
  24. Feb 20, 2020 at 11:02 PM
    plinyyounger
    Ken
    Idaho
    2025 Tundra limited
    Lol, nice! Great beer! I’ve spent a lot of time there, lol. Make sure you buy some blind pig too!
  25. Feb 21, 2020 at 3:42 AM
    coTony
    Tony
    Montrose, CO
    I have bushwacker fender flares on mine and have had no issues. I installed them myself and the weather stripping was fine (the time spent on preparation of the surface it adheres to is key) and during the install I made sure the weather stripping was in place and not rolled over then I held it in the position I needed it to be and my wife tightened enough to have me let go. It has been about 18 months and I have taken the front flares off to replace the headlights and seen no issues under them. I guess I am one luck SOB
  26. Feb 21, 2020 at 4:35 AM
    You've got a wife that helps with parts installs?! :eek2:Damn straight you're a lucky SOB!:thumbsup:
  27. Feb 21, 2020 at 6:52 AM
    Stig
    Stig New Member
    Wrenching solo in the garage is also a nice break from the wife
    GODZILLA[QUOTED] likes this.
  28. Feb 21, 2020 at 8:10 AM
    coTony
    Tony
    Montrose, CO
    Break from the wife? Thought that was divorce? :monocle:
  29. Feb 21, 2020 at 8:35 AM
    Stig
    Stig New Member
    Nah, I have my hobbies she has hers and some of them overlap. But if you think not spending 24/7/365 with your spouse would lead to divorce then keep it up.
  30. Feb 21, 2020 at 8:53 AM
    coTony
    Tony
    Montrose, CO
    Exactly what I told the wife. We are planning on retiring, buying an RV, tow the Tundra and do what we want to do. What do we want to do? Does not matter, we have the time :broccoli::dancingbacon::bananadance:
    AZTundra likes this.
