Finally weighed my truck today..
Discussion in 'General Tundra Discussion' started by Spvrtan, Feb 13, 2020.
  1. Feb 13, 2020 at 8:35 PM
    Spvrtan
    Spvrtan [OP] Amateur fabricator
    Kris
    San Diego, CA
    6,440 with a full tank of gas and no gear loaded or people inside. A stock CrewMax is around 5,500.
    Things that added significant weight:
    • Supercharger
    • Second battery
    • Sliders
    • Transmission sliders
    • Engine sliders
    • Long-travel arms
    • Compressor
    • 5 x 40" tires
    Things that reduced signficant weight:
    • Threw away the rear seats
    • Shortened the frame at the rear by 8"
    • Removed the spare tire carrier brace
    • Threw away the bed body
    Things that probably interchangeable gained/lost the same weight roughly:
    • Custom flatbed/tray
    • Custom bumpers instead of OEM
    Overall, I'm very happy with the weight. I figure adding another 300lbs for the wife and I combined, 125 for both dogs, and at most 200lbs in gear would put the weight at about 7,050. I'm working on a rear winch mount that'll add another 125 (including the winch). And also on a custom Birch plywood platform for the rear of the cab that should add 35ish.
    The truck is geared to 4.88 currently but I'll be going to 5.29 for when I go up to a 43" tire.
  2. Feb 13, 2020 at 8:43 PM
    Part_time
    Part_time Not a new member
    Oregon
    2017 MICA BRONZE SR5
    Would like to see more pics of your truck. Side view plus, those mods are major.
    Rica25 likes this.
  3. Feb 13, 2020 at 8:44 PM
    Damn Kris, that’s not bad all things considering.
    TheBeast, Spvrtan[OP] and Rica25 like this.
  4. Feb 13, 2020 at 8:46 PM
    Rica25
    Ricardo
    Tulare
    Can we see more pics bro
  5. Feb 13, 2020 at 8:49 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    http://instagram.com/spvrtan
    ColoradoTJ likes this.
  6. Feb 13, 2020 at 8:51 PM
    Spvrtan
    Kris
    San Diego, CA
    Also adding that the rear is so much lighter now that I picked up a fresh seat of leaf packs for the rear to replace my "expedition" pack from when I had a RTT, 45-gallon auxiliary gas tank, bed rack, and toolbox when I had the stock bed still.
    I'm stoked that the front/rear weight ratio is basically the same as stock, too: 56/44 (%).
    drobb, Rica25 and ColoradoTJ like this.
  7. Feb 13, 2020 at 8:53 PM
    Any extended plans to link the rear with some coilovers?
    Rica25 likes this.
  8. Feb 13, 2020 at 8:53 PM
    Spvrtan
    Kris
    San Diego, CA
    These are just from today I guess..
    And from King of the Hammers last week..
    plumber802 and Rica25[QUOTED] like this.
  9. Feb 13, 2020 at 8:56 PM
    Spvrtan
    Kris
    San Diego, CA
    I'm planning on adding at least beefy traction bars but I'll probably keep the leaf spring setup to continue with the build goal of proving out the stock mechanical designs.
    ColoradoTJ[QUOTED] and Rica25 like this.
  10. Feb 13, 2020 at 9:06 PM
    Can’t blame you there. If it works well for you, no reason to change.
    Thanks for the update on your build.
    Rica25 likes this.
  11. Feb 13, 2020 at 9:08 PM
    Spvrtan
    Kris
    San Diego, CA
    Yeah, it's about at 90% where it needs to be before I call it done and move onto a new build.. either a 1st-gen Tundra.. or the Cybertruck once my reservation spot comes up.
  12. Feb 13, 2020 at 11:14 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    That thing is crazy nice work.
  13. Feb 13, 2020 at 11:53 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    Did you weigh it stock before you modded or are you going by the OEM number?
  14. Feb 14, 2020 at 7:54 AM
    Spvrtan
    Kris
    San Diego, CA
    OEM for SR5 CrewMax.
  15. Feb 15, 2020 at 1:40 PM
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    My stock 17 Sr5 Crewmax 4x4 weighs right now 6300. Frt is 3360 rear 2940.That includes 240 lbs in the bed ,no people
  16. Feb 15, 2020 at 2:13 PM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My 007 SR5 regular cab weighs in right at 5000 lbs. with a full tank of gas, no wonder I come off the line so much quicker than most other Tundra trucks.
  17. Feb 24, 2020 at 11:33 PM
    Spvrtan
    Kris
    San Diego, CA
    That's not bad. Try and keep track of the weight as you modify the truck, too.
