Finally putting her to the test
Discussion in 'Towing & Hauling' started by ktugboat42, Jun 28, 2018.
  1. Jun 28, 2018 at 9:13 AM
    ktugboat42
    ktugboat42 [OP] New Member
    Pete
    Cape Cod
    2018 Cement Tundra TRD Double Cab
    So this is the first time i'm towing my 26' Mako with the new Tundra. Pretty impressive except for the squat due to about 700 lbs of tongue weight.
    I also just bought this little ole pop up camper that has a dry weight of 1030 lbs. We went camping for the a night and had no real issues at all except I need to figure out a better tie down system for it since the eye bolts are right over the bed rail cap. Does anyone know the d rings weight capacity in the bed?t camper.jpg
    Lake.Life24, NCinCO, blue16 and 4 others like this.
  2. Jun 28, 2018 at 10:39 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    Nice! Which weight distribution hitch are you using for that boat?
  3. Jun 28, 2018 at 11:13 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    how much does the boat, trailer, fuel, and gear weigh?
    parallax likes this.
  4. Jun 28, 2018 at 11:25 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Dry weight 1030 lbs on that camper. That doesn't leave much payload to play with. 500-600 lbs? Minus how much for the people? Gear?
    Just sayin.....
  5. Jun 28, 2018 at 11:28 AM
    01erionracing
    01erionracing KJ6RKU
    Jimmy
    2000 SR5 4WD 2002 SR5 4wd 2008 CM Limited 4wd
    Firestone air bags will solve this issue.
  6. Jun 28, 2018 at 12:43 PM
    Torqelift has everything you need for proper tie downs. On the rear, you can use button mounts, but I’m not sure how robust the bumper is to hold that kind of force.
  7. Jun 29, 2018 at 12:04 AM
    ktugboat42
    Pete
    Cape Cod
    None but im thinking about getting one.
    Probably around 7000 lbs so well within limits and not nearly as heavy as the space shuttle.
    I'll have to check that website out for tie down options.
  8. Jun 29, 2018 at 1:16 AM
    ktugboat42
    Pete
    Cape Cod
    Im looking at the Firestone ride rite kit for air bags.
    01erionracing[QUOTED] and Adam like this.
  9. Jun 29, 2018 at 2:41 AM
    Adam New Member
    I installed a set of those on my dads F150 a few years back. Pretty easy to do. He loved them for his in bed camper.
  10. Jun 29, 2018 at 6:41 AM
    Atomic City Tundra
    Devin
    New Mexico
    Oh. Ok. Then it must be totally within payload limits. o_O
    I was just commenting that you don't have much room left before technically being overloaded. Not sure how many people you take with you on your camping trips, but I know that my family of five would chew up all of that extra payload. And 1030 dry weight is not what you haul when you go camping. You take gear. I know that I can easily rack up hundreds of pounds of gear.
    Yeah, the Tundra will do it. But should it? The Tacoma probably shouldn't have (although there are certain configurations of Tacomas that have around 1600 lbs of payload also).
  11. Jun 29, 2018 at 7:52 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    You should definitely get one. Anything over 5000 lbs requires one according to the manual. The hitch will fix the squat since your 7k lbs is well within load limits
    Sunnier likes this.
  12. Jun 29, 2018 at 8:21 AM
    ktugboat42
    Pete
    Cape Cod
    Wouldn't air bags do the same thing and also help out with the slide in camper weight basically killing two birds with one stone?
  13. Jun 29, 2018 at 8:41 AM
    Ike74
    Ike74 New Member
    Anthony
    Sugar Land, TX
    2020 Kia Forte
    That would help with the camper, but I still wouldn't deviate from the owner's manual on the hitch. Also, a WDH is much safer for carry those types of loads. @ColoradoTJ can tell you more about that
    NewImprovedRon likes this.
  14. Jul 1, 2018 at 3:43 AM
    astro-jason
    astro-jason New Member
    2022 CHEVROLET 3500 CC L/B Duramax 10spd
    Adjust the boat, move it back on the trailer. looking at the picture you have the room. Did you buy the boat and trailer new? If not, it was set up to the previous owners truck. A WDH for a boat is a pain in the ass.
    -Jason
  15. Jul 6, 2018 at 4:59 AM
    ktugboat42
    Pete
    Cape Cod
    I bought it used.
    It tows great but im going to try and weigh the tongue weight next week to see if i should move the boat back a little.
