Finally Joined the Club!
Discussion in 'New Member Introductions' started by HookedWS, Apr 8, 2019.
  1. Apr 8, 2019 at 9:03 AM
    HookedWS
    HookedWS [OP] New Member
    Corin
    2014 double cab SR
    Greetings all! After many years of dreaming and lurking in this forum I finally can call myself a Tundra Owner. I just traded my 2005 F150 Supercab FX4 in for a 2014 Double Cab 4x4 <19K miles. Super excited to be a part of this community!
  2. Apr 8, 2019 at 9:04 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :wave: Hiya and welcome from SoCalif!!!
    HookedWS[OP] likes this.
  3. Apr 8, 2019 at 9:04 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Welcome from CO. What made you switch from Ford?
  4. Apr 8, 2019 at 9:05 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    Welcome from UT! Nice upgrade!
  5. Apr 8, 2019 at 9:06 AM
    HookedWS
    Corin
    2014 double cab SR
    Thanks!
    My Ford had 210K miles on it and the timing system was going for the 2nd time. Instead of sinking more money into knowing the transmission only had a couple years left I traded while it was still running. I got the ford a couple years ago when I couldn't afford a Tundra but have never been a die hard Ford guy.
    Ostrich and Black Wolf like this.
  6. Apr 8, 2019 at 9:06 AM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    Welcome from Tn, you will not regret dropping the Ford.
  7. Apr 8, 2019 at 9:07 AM
    HookedWS
    Corin
    2014 double cab SR
    thanks! (From OH) I don't think I will :)
  8. Apr 8, 2019 at 9:08 AM
    Welcome from Texas
  9. Apr 8, 2019 at 9:14 AM
    Welcome from Colorado.
  10. Apr 8, 2019 at 9:14 AM
    Welcome from Ohio.
    HookedWS[QUOTED][OP] likes this.
  11. Apr 8, 2019 at 9:16 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Welcome from TX!
    Great color! :thumbsup:
  12. Apr 8, 2019 at 9:18 AM
    HookedWS
    Corin
    2014 double cab SR
    Thanks! It looks a hell of a lot better than my Red Ford with rusted cab corners :rofl:
  13. Apr 8, 2019 at 9:23 AM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
  14. Apr 8, 2019 at 9:26 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Welcome from AZ!
  15. Apr 8, 2019 at 9:29 AM
    Ostrich
    Ostrich One bit me once.
    Nikki
    Marion, Texas
    2014 MGM Crewmax SR5 4x4
    3/1 level, black leather, raptor style grille
    Welcome from Tx!
  16. Apr 8, 2019 at 9:51 AM
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    Welcome from SE PA!
  17. Apr 8, 2019 at 10:52 AM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    Welcome from SoCal... :cheers:
  18. Apr 8, 2019 at 10:52 AM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    Welcome from SE Ohio. Nice color.
  19. Apr 8, 2019 at 10:54 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    Welcome from Va! What did you get the Tundra for if you don’t mind sharing? I ask because there is another thread about new vs used pricing. I started to look for used but ended up with a 2019 Tundra Double Cab, 4x4 5.7L
  20. Apr 8, 2019 at 10:55 AM
    Welcome!
  21. Apr 8, 2019 at 11:00 AM
    HookedWS
    Corin
    2014 double cab SR
    Got it for 25k after trade in before taxes and fees. Is 5 years old but has BT, backup cam and just under 19k miles on it so I felt like it was a pretty good deal. 19k on a Toyota is barely broken in.
  22. Apr 8, 2019 at 11:01 AM
    NCTundra18
    NCTundra18 New Member
    Jeff
    Candler, NC
    2018 White Limited Crewmax
    TRD dual exhaust, Rough Country lift kit and too much money spent.
    Welcome from NC.
  23. Apr 8, 2019 at 11:14 AM
    Welcome from NY.
  24. Apr 8, 2019 at 12:08 PM
    Tempest
    Tempest You feel lucky??!!
    2015 Limited TRD
    Welcome from AZ! :tumbleweed:
  25. Apr 8, 2019 at 4:15 PM
    Larmand
    Larmand SSEM #6
    Lucas
    Fort Worth, TX
    Welcome to the party!!
  26. Apr 8, 2019 at 5:14 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  27. Apr 8, 2019 at 5:16 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Welcome from SE VA. .;)
  28. Apr 8, 2019 at 5:18 PM
    JRider600RR
    JRider600RR New Member
    Memphis TN
    14 Tundra Platinum
    Welcome to the forum
  29. Apr 8, 2019 at 5:48 PM
    Britrider750
    Britrider750 Old dude with cool truck.
    Ron
    Clayton, North Carolina
    2017 TRD Off Road
    All weather Tundra floor mats, spray bed liner Extang Trifecta 2.0 tonneau
    Welcome from Upstate NY.
    Dream fulfilled.
    Now dream about mods!
  30. Apr 8, 2019 at 5:53 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
