fighting the man
Discussion in '2.5 Gen Tundras (2014-2021)' started by Wundra, Jan 20, 2023.
  1. Jan 20, 2023 at 2:32 PM
    Wundra
    Wundra [OP] New Member
    Just joined as it appears tundras.com is now where it's at...
    Currently driving a 2021 tundra after retiring a 2008. I loved that 2008 and would have been happier with that same truck brand new. So now I'm doing what I can to get rid of all the tech, nannies, and options that's possible.
    I spent a half hour fixing the settings and turning off everything that I could.
    I value my privacy and want to disconnect from toyota completely. I don't have any subscriptions, but I believe there's some sort of connection:
    I called toyota and am still trying to understand what's on and what's not. It sounded like the guy I spoke with had never heard of someone asking for this before, but he said I could send in proof of ownership and they'd do something ... I'm not holding my breath.
    So is there a way to essentially unplug the wifi connection? I never want to start the truck and get a message asking if I want to update my entune app again.
    Just to head it off...
    I don't use Sirius
    the maps app
    wifi
    the Toyota OnStar (can't remember the name)
    etc.
    Gene_in_FL, DarkMint, 2mchfun and 2 others like this.
  2. Jan 20, 2023 at 2:41 PM
    Welcome from NY.
  3. Jan 20, 2023 at 2:48 PM
    Kajunxplorn
    Kajunxplorn New Member
    2021 Silver Limited CM TRDOR
    Welcome
    IsaiahCanada likes this.
  4. Jan 20, 2023 at 2:59 PM
    TaquitoBandito
    Joel (AKA Bif)
    Welcome from Central Texas. Hopefully you find the answer you are looking for.
    Until then, you can do what I do:
  5. Jan 20, 2023 at 3:54 PM
    2mchfun
    Welcome from OKC! Lots of us on the same page:cool:
  6. Jan 20, 2023 at 4:03 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Welcome aboard.,, they already know all they need to know about you.
  7. Jan 20, 2023 at 4:12 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    Well, as far as mods go, my first was to put on better tires, my second was to get rid of the Toyota head unit, and put in a kenwood
    el_conquistador likes this.
  8. Jan 20, 2023 at 4:25 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    If you pull the big red wire off the truck battery it should kill the power to your head unit and they can't see you driving.
  9. Jan 20, 2023 at 5:28 PM
    Wundra
    How about if I close my eyes?
    Gene_in_FL, batman900 and landphil like this.
  10. Jan 20, 2023 at 5:36 PM
    Wundra
    First few mods were taking off the side steps, cleaning up some badges, leveling kit, bedliner, better tires, ...
  11. Jan 20, 2023 at 5:45 PM
    Wundra
    Ok, so we can assume that toyota doesn't want to make it too easy so that a thief can't just pull a wire and then the engine dis-abler won't work. But there's got to be a workaround. Where are all the wifi/GPS/hot spot components located?
    There's a box under the front passenger seat that looks a bit like a modem. (I'm not a IT professional though.)
  12. Jan 20, 2023 at 5:52 PM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    Take a saw to the shark fin on top of your truck. Believe that is where all the gps antennas are
    Tripleconpanna likes this.
  13. Jan 20, 2023 at 5:54 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    The shark fin on top of the roof is where all the GPS, etc. antennas are located. There are a few videos floating around the internet where folks have removed them to eliminate 'connectivity'... You may want to search 'tundra or toyota shark fin'; most vehicles (not just Toyotas) have one of these now... However, before you go ripping it off the roof... there are so many computers controlling the vehicle's functions and its systems, that I'd be concerned your truck would start tossing CEL codes and give you functionality issues.
    Also, don't forget these trucks now have a 'black box' of sorts (Event Data Recorder) which is capturing images, conditions, driving habits, etc. and is designed to be used by engineers to analyze and fix issues surrounding events related to the vehicle. This same system can also be accessed by a Toyota dealer or other entity (investigation teams) in the event of an investigation and upon request/subpoena (accident, vehicular homicide, etc.) by various authorities...
    All that being said, as already stated, unless you are already completely 'off the grid' and don't have/drive with a modern cell phone, etc... it's all a moot point.
    I hope you enjoy your new rig and find some balance between your privacy and keeping the main truck systems functioning :thumbsup:
    Jackstraw and TaquitoBandito like this.
  14. Jan 20, 2023 at 6:10 PM
    Wundra
    Sometimes I send my phone on it's own vacation to keep the satellites guessing where I'm at.
    I'm guessing the truck's computer looks for a signal from various locations like the black box, etc. before allowing the vehicle to even start, let alone triggering a CEL. But now you're telling me I need to figure out how to bypass the black box as well as everything else.
    I used to think I was a semi-normal truck owner not wanting all these add-ons, electronics, safety features, and nannies. But as I read forums and reviews I've come to realize that most people these days want all this. I was close to buying a 2022, but that takes it even further.
    Gene_in_FL and Jackstraw like this.
  15. Jan 20, 2023 at 6:14 PM
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    Get a 1st gen.
    Or wrap your shark fin antenna in aluminum foil glued on with some Permatex Ultra Black.
    Labrayota, MS22, Black@Blue19 and 2 others like this.
  16. Jan 20, 2023 at 6:35 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
  17. Jan 20, 2023 at 7:05 PM
    Tripleconpanna
    The 'black box' is pulling data (mostly digital but some imagery) from the vehicle's other computers to register speed, pitch, braking (yes or no), and numerous other driving "behaviors"...
    Unfortunately, as folks want more seamlessness between their phones, their vehicles, their habits, and the rest of their lives they have 'invited' a pathway for the types of things that concern you to be present w/o question and almost on a compulsive level. So, yeah, short of getting a Gen 1 or early Gen 2 Tundra you're probably spinning your wheels (no pun intended) on avoiding most of these things that concern you w/o risk to the rest of the systems...
    TaquitoBandito likes this.
  18. Jan 20, 2023 at 7:09 PM
    Tripleconpanna
  19. Jan 21, 2023 at 2:08 AM
    :wave:
  20. Jan 21, 2023 at 4:18 AM
    dondino
    dondino New Member
    don
    2007 Tunda Crewmax
    Welcome from the rust belt.
    PermaFrostTRD likes this.
  21. Jan 21, 2023 at 4:39 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Welcome from New Hampshire, congrats on your new truck.
  22. Jan 21, 2023 at 4:58 AM
    PermaFrostTRD
    Northern NY
    Welcome from NNY. Did you buy the truck with cash?
    If not, everything you’re asking to do is already too late. :notsure:
  23. Jan 21, 2023 at 8:01 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    My truck is a 2016. I will never buy a newer one than this. My next truck actually might be an early 90's model.
    Tripleconpanna and 2mchfun like this.
  24. Jan 21, 2023 at 8:08 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Leo's first likes this.
  25. Jan 21, 2023 at 9:06 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
  26. Jan 23, 2023 at 12:09 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Do you also wear green so you can hide?
    It won't work, they'll still find you! :rofl:
    Tripleconpanna and PermaFrostTRD like this.
