ffffff....oil filter housing
Discussion in 'General Tundra Discussion' started by tstieb, Nov 9, 2019.
  1. Nov 9, 2019 at 10:49 PM
    tstieb
    tstieb [OP] New Member
    2014 CM TRD
    Went to drop the oil tonight and have cracked the oil filter housing and snapped off 3 of the 4 tabs on that plastic POS. I have the metal version that I was going to put on tonight, but now I'm in a bad spot and can't drive the truck. Anyone have any ideas?
    It seems my options are to have it towed to a Toyota mechanic and see if they can get it off, try to find a mobile mechanic that might have Tundra experience to try and do the job, or see if I can drill a hole through the housing to stick a punch through it to try and get it off that way. But I'm not sure I can get a drill in there with a bit that is big enough that would allow a good sized punch to go in.
    I torqued it down last time and in fact didn't even hit the 18lb ft before it stopped turning, so I'm not sure why it won't come off.
    Any suggestions on mobile mechanic (SE Aurora, CO) or what else to try would be greatly appreciated. TIA
  2. Nov 9, 2019 at 11:05 PM
    AZBoatHauler
    So.Arizona
    NewImprovedRon and tstieb[OP] like this.
  3. Nov 10, 2019 at 2:36 AM
    tstieb
    2014 CM TRD
  4. Nov 10, 2019 at 3:00 AM
    Steve New Member
    2015 Tundra Crewmax SR5 TRD 4X4
    TRD dual exhaust
    This happened to me as well. I took a sheet of paper, folded it a few times and held it up to the housing and forced the wrench over the paper. Has to be extremely tight. Dealer put mine on so tight I needed a breaker bar to get it off. There is a video of this on YouTube
    VRC and tstieb[OP] like this.
  5. Nov 10, 2019 at 3:08 AM
    Steve New Member
    TRD dual exhaust
    YouTube video title: Watch before you break a stuck oil filter housing
    tstieb[OP] likes this.
  6. Nov 10, 2019 at 3:12 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    I broke mine too, managed to get a metal replacement from Advance Auto. Duct tape and channel lock/pipe wrench.
    I need to figure out how to make an adapter/relocation/cap pointing up like the Mercedes.
  7. Nov 10, 2019 at 6:00 AM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
    My mechanic broke mine. (had all the drivetrain fluids changed) A tab broke off and in the process it cracked the housing causing a leak. Don’t know where or who changed the oil last, bought the truck used.
    He called right away and told me, replacement was ordered.
    After picking up my ride I went to the parts counter of my local stealership, bought a metal housing and changed out the inner perforated tube to the proper longer one.
    It doesn’t have to be over tightened to stick. It’s like the o-ring melts and welds the parts together.
    The Toyota part is: Cap Assy, Oil Filter 15620-31060
    Next oil change (and all other fluids) will be changed by me now that I have the tools and parts.
    Pity the tranny isn’t easy to service. I’d like to do a drain and fill without having to putz around with the goofy tranny set up we have in 3rd gens.
    15whtrd and tstieb[OP] like this.
  8. Nov 10, 2019 at 6:20 AM
    gears_call
    gears_call New Member
    Orange County, CA
    2014 SR5
    King 2.5's l Method double standards l 35" BFG KO2 l SS Built front bumper/skid/valence l more to come....
    I broke mine as well. I did the above mentioned with the paper and it worked for me. Also it’s my only vehicle and needed it for work the next day so I put it back on with some oil filter pliers and got my replacement in the mail a few days later. Simply removed again with oil filter pliers and was good to go
  9. Nov 10, 2019 at 6:55 AM
    tstieb
    2014 CM TRD
    Thanks for all the responses. I'm going to try the paper trick later this morning. But I've already broken the three tabs on one side, so I'm not sure how well it will grip in the filter socket. Really hope it works out. Will post later w results.
  10. Nov 10, 2019 at 6:58 AM
    AZBoatHauler
    So.Arizona
    I’ve also wrapped tape around the bottom of a filter to build it up and make it fit on a filter wrench a little tighter. That might be easier than trying to use paper.
  11. Nov 10, 2019 at 7:37 AM
    Glockmeister
    It’s such a stupid design. WHY!?!?!
    A regular can filter would work just fine, why are we saddled with this goofy ass setup?
  12. Nov 10, 2019 at 7:42 AM
    tstieb
    2014 CM TRD
    Yeah, I could use a regular filter wrench and be done with it much quicker and easier.
  13. Nov 10, 2019 at 7:46 AM
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Thanks for posting this. I’ll be doing my first oil change next month, so I just ordered the aluminum housing to avoid this.
    My wife’s 2015 highlander came with the aluminum version. Not sure what Toyota was thinking.
  14. Nov 10, 2019 at 7:54 AM
    tstieb
    2014 CM TRD
    I did my wife's 4runner a few weeks ago and now I'm shitting bricks that this is going to happen with it as well. I'll have to look to see if the aluminum housing works in the 4runner as well or if they have one available.
  15. Nov 10, 2019 at 11:31 AM
    tstieb
    2014 CM TRD
    I can hardly believe it but the paper trick worked! Thanks @Steve and all the other suggestions.
    I still had to use a breaker bar and mongo the shit out of it, but it finally budged. Thank goodness.
    RangerBP and AZBoatHauler like this.
  16. Nov 10, 2019 at 12:14 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    WONDERFUL. Now remember that when putting the filter canister cap back on you only really need it snug plus a widdle biddle bit. And then you'll never have the problem again.
    Again >>> CONGATS!!!!
    tstieb[QUOTED][OP] likes this.
  17. Nov 10, 2019 at 1:09 PM
    aussieaarons
    aussieaarons die with memories, not dreams
    2019 Cavalry Blue TRD
    2” level, roof mount DVD, interior LED bulbs, sumosprings out back, OEM folding cover, Blackout emblems
    Do you have a link for the housing your ordered? Thanks
  18. Nov 10, 2019 at 2:08 PM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
  19. Nov 10, 2019 at 3:01 PM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    tstieb[OP] and AZBoatHauler like this.
  20. Nov 10, 2019 at 4:46 PM
    AZBoatHauler
    So.Arizona
  21. Nov 10, 2019 at 6:53 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    If tossing anyway, drill a hole in the side, stick a beefy screwdriver in it and use as leverage to unscrew.
    Have done this on regular oil filters before.
  22. Nov 11, 2019 at 4:46 AM
    db52282
    db52282 New Member
    David
    Georgia
    2017 Silver Tundra Limited
    I bought my truck a few weeks ago. Changing out the plastic filter housing is top on my list of things to do.
    Could you try a big pair of channel locks or one of those spin on filter removal tools?
    I have been successful in the past using those. Hope you get it off without too much hassle.
  23. Nov 11, 2019 at 7:19 AM
    tstieb
    2014 CM TRD
    Luckily I got it off with the paper in the filter wrench trick. Saved me a bunch of money!
