Fender removal help
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Feb 9, 2020.
  1. Feb 9, 2020 at 12:06 PM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    I’m in the process of removing my driver side fender as there’s a dent I wanted my buddies shop to handle for me. I believe I have one last bolt to remove, it’s right about where the bumper and fender meet just above and past the tire.
    I can’t seem to get this nut off with a 10mm socket, and upon looking there’s another head I can remove on the other side but I can’t reach without bumper removal. Anyone do this before, and if so did you have to remove the bumper? Thanks!
  2. Feb 9, 2020 at 9:20 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Never removed a fender off of my Tundra so I don't have any tricks or specific advice on that. But looking at your pictures it looks like your rounding/stripping the nut. A good quality 6 point socket or tubing style wrench might get a good fit and get it loose or one of those sockets designed to remove rounded nuts might do the trick also.
  3. Feb 9, 2020 at 10:13 PM
    TFT
    TFT New Member
    Troy
    2017 Tundra Limited
    Maybe some penetrating oil/WD 40 in there will help it break free.. looks rusty.
  4. Feb 9, 2020 at 10:39 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    the nut is welded on. theres a bolt on the other side.
    At least if i remeber right.. its been over a year since i tore my fender off
    tvpierce and MrAristo[OP] like this.
  5. Feb 10, 2020 at 1:58 AM
    zombie
    zombie Master at Something
    paul
    Rhode Island
    2007 Black DC 4x4
    No need to remove bumper. Do not use WD/40, it is not a rust penetrater, it is a rust preventer, look it up. PB blaster, soak it a few times, sometimes over night. A 10mm swivel socket might work, in the 1/4" drive. Of course if you had torches, a little heat works the best. Not the same as propane.
    MrAristo[OP] likes this.
  6. Feb 10, 2020 at 4:34 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Yes thanks. I’d been using exactly that; small swivel socket w 1/4” drive & 10mm socket along w WD40. Going to use PB today and see if that works.
  7. Feb 10, 2020 at 5:17 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    It appears to me you need a deep 10mm socket for that nut. Stud extension interferes internally with a standard length 10mm socket, and prevents the socket from engaging the hex flats. You end up rounding the hex corners on the top of the nut. Use a 10mm end wrench if you don't have a deep 10mm socket.
  8. Feb 10, 2020 at 5:25 AM
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    yep, it comes off. the nut is welded, it's just a bolt. PIA to get it off.
  9. Feb 10, 2020 at 12:33 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Was able to FINALLY get that last bolt off. What made it super difficult (with bumper on) is the narrow space to operate between bumper and this bolt, while still torquing off. Had to buy a very small swivel socket, turn to about 120 degree angle and work at the bolt ever slowly while also pushing on the bumper to give a little more room. Thanks to @zombie for the PB Blaster recommendation also. New fender (and rear chrome bumper also) on the way!
  10. Feb 10, 2020 at 2:20 PM
    Professional Hand Model
    Hand Protectors
    How did you remove that quarter panel?
    I want to snug up my door hinge bolts and make a small adjustment on the passenger side door.
    mcharfauros likes this.
  11. Feb 10, 2020 at 4:03 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Check this out:
  12. Oct 14, 2020 at 5:04 AM
    Bwildered
    Bwildered New Member
    00 SR5
    Hopefully people scroll down to here.
    IT'S SO SIMPLE. "Take off the two large bumper bolts on the driver's side and the vertical nut under the *$#&@ WELDED nut, and the bumper will drop just enough to easily remove the fender bolt from Hades."
