Fender flares
Discussion in '3rd Gen Tundras (2022+)' started by F150 blowz, Feb 3, 2024.
  1. Feb 3, 2024 at 6:48 AM
    F150 blowz
    F150 blowz [OP] New Member
    Michigan
    2023 CM SR 4x4
    I have an SR 2023 Tundra, so no flares from the factory. I changed out the hideous steel wheels and tires for some FN Wheels BFDs. Now I need some fender flares (and mud-flaps, but that’s a different thread). Does anybody run the rough country sport flaps? It looks like they mount over the top of the factory existing flares, which I don’t have. I could get the TRD pros, but those also mount over top of the normal flares.
    If anybody knows of any other flares they would recommend, please do so. I’m trying to avoid the fake bolt on look.
  2. Feb 3, 2024 at 7:13 AM
    TundraTT
    TundraTT Full Send
    17 Pro, 94 70series LC
    You won’t have any of the clip holes for the various factory flares. Best bet is to check the rough country mounting locations and compare.
    ryanwgregg likes this.
  3. Feb 3, 2024 at 7:16 AM
    F150 blowz
    Michigan
    2023 CM SR 4x4
  4. Feb 3, 2024 at 7:17 AM
    F150 blowz
    Michigan
    2023 CM SR 4x4
    I’ll call rough country on Monday, hopefully someone can tell me for sure what will fit or not.
  5. Feb 3, 2024 at 7:20 AM
    F150 blowz
    Michigan
    2023 CM SR 4x4
    Understood. So the only option will be aftermarket?
  6. Feb 3, 2024 at 8:31 AM
    PBNB
    PBNB Needy
    Peter
    Vancouver, BC
    2023 Z71 3500 HD
    Lots of stuff!
    You could make the TRD Pro flares work but it would require a bit of work to create some mounting points and using some VBH tape. The big advantage is you could wire in the lights and that would be a first for an SR I think!
    The rough county flares might work but they might be more along the lines of sticking them over your stock flares so again, you would have to do some work to make them fit.
    Either way, you will probably need to make some holes to mount to flares on the inside of the fender lip. It might be that the fender liner is secured to holes that you can use for flares.
    I have a set of black flares sitting in a box that came off mine when I put the TRD Pro flares on, if only you were closer!
  7. Feb 26, 2024 at 10:23 AM
    Toyota1990
    Toyota1990 New Member
    Rough country flares fit gen 3 SR without any modification.
    Johnny230 likes this.
