Fender clearance question.
Discussion in 'General Tundra Discussion' started by FirstGenTundra, Jun 17, 2016.
  1. Jun 17, 2016 at 6:06 PM
    FirstGenTundra
    FirstGenTundra [OP] R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    So I broke out the tape measure tonight to discover that my trucks passenger side wheel well (rear) sits a full 1 inch higher than drivers side. I'm a little puzzled by this. I know the fuel tank is on driver side but even so it only has half a tank. Anyone else made this observation? Front wheel both measure in very close to each other.
  2. Jun 17, 2016 at 7:07 PM
    FirstGenTundra
    Daniel
    Wyoming
    Thanks Ron! My front tire wheel wells also measure in right about 37in from pavement to top of wheel well. It was the rear wheel wells where I discovered the difference. One side was 39 the other 40. Sorry I didn't specify that. And my 14 only has 15250 on it so far. :D
  3. Jun 17, 2016 at 7:14 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    Yeah, the fuel tank, the battery and the driver all sit on the same side. Makes it lean after a while, noticed that on all my previous trucks.
  4. Jun 18, 2016 at 3:10 AM
    FirstGenTundra
    Daniel
    Wyoming
    Ok, so long as it's normal. :D Thanks guys!
  5. Jun 18, 2016 at 10:04 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    It's the famous Yota lean. The Tacos have it too. Some guys add a CB shim up front on the drivers side to level it off
  6. Jun 18, 2016 at 11:03 AM
    FirstGenTundra
    Daniel
    Wyoming
    It doesn't bother me that bad just wanted to make sure I didn't have an issue before my road trip to Wyoming. :woot:
    boardude likes this.
  7. Jun 18, 2016 at 11:12 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    So what kind of lift are you running?
  8. Jun 18, 2016 at 11:29 AM
    FirstGenTundra
    Daniel
    Wyoming
    No lift, stock truck. The 37in was in reference to the measurement from pavement to top of wheel well. That was not clairified well. Will edit. Sorry for that confusion. :tinfoilhat:
  9. Jun 18, 2016 at 5:13 PM
    dandailey
    Dan D
    Newport News Va.
    Was going to say, no lift ,then you weren't running 37"tires.
