Feeling stupid Door locking question....
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by Joyinc, Aug 21, 2019.
  1. Aug 21, 2019 at 5:05 PM
    Joyinc
    Joyinc [OP] New Member
    Ward
    2017 Tundra SR5
    I just bought my 2017 SR5 and noticed that when I hit the unlock button on the remote it chimes once. When I hit the lock button I get no chimes at all. I would rather know my truck is locked versus unlocked. How do I change this. Please note that the infotainment system was replaced with a double din touch screen unit (cheap one) and I think that this is where I need to be to make the change... Am I correct or is there another way?
  2. Aug 21, 2019 at 5:16 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    So my truck is a 2012 but I'll share my story.
    For the past 2 years I've had my truck it would chime when I hit the lock button on the fob.
    One day (a month or so ago) I hit the lock button and I heard nothing.. Figured it was a fluke and walked away.
    Well it did it again the next day. I looked around, hit unlock and then lock and it chimed. I was getting an intermittent no chime when locking it with the fob.
    Come to find out my passenger side front door lock actuator was going out intermittently. If one of the door lock actuators does not lock when you hit the button on the fob then the truck will not chime.
    I would check your doors to make sure they are all locking. If they are all functioning I would bet the dealer can hook up to it via tech stream and program it to chime when you lock it with the FOB.
    bdpeelgren, Black Wolf, Pudge and 2 others like this.
  3. Aug 21, 2019 at 5:26 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Mine chimes both ways so it’s gotta be in the settings. Also for a little while I had it set on driver door unlock only, double press for all doors. Finally changed it to single press all unlock as my family is often getting in same time.
  4. Aug 21, 2019 at 5:28 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    How did you change that?
    Mnorris1206 likes this.
  5. Aug 21, 2019 at 5:34 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    It's a setting in Entune if you have the stock head unit and can also be done in Techstream. I THINK people with aftermarket head units might be able to change it if they have an iDataLink Maestro. I changed mine to unlock all pretty much right away after getting my truck.
    OP, sounds like you've got an actuator problem like @Scuba mentioned. Also, you should have two beeps for unlock, one for lock...
  6. Aug 21, 2019 at 6:03 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    Figured.
    My truck came second hand with an AM head unit and no Maestro. I'm too poor to buy the maestro kit. Maybe if I'm bored one day I'll head to the dealership to see if they can change it via Techstream. Thanks!
    Black Wolf likes this.
  7. Aug 21, 2019 at 8:14 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    My aftermarket head unit has an icon called “Console” and within it “Car Settings”, ie; it retained the stock HU’s controls. I installed it, no special cables required but the new HU did have ports for all the stock harnesses.
    In “Car Settings”, there’s a choice for “Sound for Lock/Unlock”. It’s set at “7” which doesn’t make any sense, I just know it beeps both ways. Someone with the stock Tundra HU may be able to tell you if there are separate settings for what you’re experiencing.
    One thing, mine doesn’t beep if my kid doesn’t fully shut a door. So make sure even with no sound, all doors are fully locking.
  8. Aug 21, 2019 at 8:20 PM
    X2
    Welcome from NY.
    OR18TRD[QUOTED] and Conflicted like this.
  9. Aug 21, 2019 at 8:32 PM
    Conflicted
    Conflicted New Member
    Buffalo-ish, New York
    2019 Crewmax SR5 TRD Off Road
    I keep it really clean!
    May be dumb to point out but I've noticed with some aftermarket remote start systems the fobs don't work correctly in corresponding with the chimes or the headlight flashes when locking or unlocking. Just a thought
    JH5370 likes this.
  10. Aug 21, 2019 at 8:33 PM
    Conflicted
    Also.....welcome again from NY :thumbsup:
  11. Aug 21, 2019 at 8:36 PM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    2017 White DC TRD PRO
    I read a thread on here where someone had an aftermarket alarm that screwed with the chimes and ended up being an ordeal to get fixed.
  12. Aug 21, 2019 at 11:09 PM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    My truck has a constant high pitched tone that plays if I try to lock the truck and a door isnt fully closed. It will make noise until I hit unlock or close the offending door.2016 sr5
    Ostrich likes this.
  13. Aug 22, 2019 at 3:38 AM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    I have a Kenwood head unit that has no settings for my truck, but my Bullydog tuner allows me to change or disable many of the alarm features. ALL of my alarms are turned off, including when you lock and unlock. I think most modern vehicles have WAY too many alarms. Why does everything have to beep at you?!? The vast majority of alarms are pointless in my opinion. I can hear my truck lock and it also flashes, so an alarm to me is overkill. I prefer the sound of silence, but that's just me. :spy:
  14. Aug 22, 2019 at 4:27 AM
    coTony
    Tony
    Montrose, CO
    There is a setting that can be changed using TechStream
  15. Aug 22, 2019 at 4:30 AM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Check the actuators. Same thing happened on our Venza. They would unlock, get the beep but no beep on lock and 3 out of 4 doors were not locking.
  16. Aug 22, 2019 at 7:42 AM
    JH5370
    JH5370 Member
    Josh
    Eastern WA
    I agree that most alarms are overkill. Especially the seat belt chime, but I do like the lock beep. I always double check my truck is locked before I go to bed and I can hear the beep without having to walk to a window to look for the lights. The unlock double beep on the other hand is annoying. I have to hear it twice if I want to open the passenger door. If I am unlocking the truck then I am close enough to hear the locks and don't need more shit beeping at me.
    Kerch71[QUOTED] likes this.
  17. Aug 22, 2019 at 7:38 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    I like the lock beep too, I can think of a few situations when I can’t see my truck like in a crowded lot or if I’m walking away. The beep sound means I don’t have to look back.
  18. Aug 23, 2019 at 6:46 AM
    Joyinc
    Ward
    2017 Tundra SR5
    Wow, Thanks everyone for replying. I am having a nice Kenwood system put in next week with Maestro so I hope I get those features back.
    JoshuaA likes this.
  19. Sep 24, 2019 at 3:33 PM
    Glockmeister
    Glockmeister New Member
    North of the summer hell
    ‘17 Crewmax SR5 4X4 TRD
