Feathering tires only 8000 miles, 2018 cm
Discussion in 'Wheels & Tires' started by phabej, Jun 6, 2019.
  1. Jun 6, 2019 at 1:24 PM
    phabej
    phabej [OP] New Member
    NO LONGER HAVE A TUNDRA... Waiting
    Update here Feathering tires only 8000 miles, 2018 cm
    Anyone have any idea why my tires would be feathering?? Front tires, most visible on the front passenger outer threads.
    I don't drive aggressively or corner too hard. I only have 8k on the truck.
    Sports CM with sway bars.
    I will likely call the dealership since it's under warranty but just wanted to get some ideas as to why this is occurring.
    Thanks
  2. Jun 6, 2019 at 1:28 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    Have you had the alignment checked? Toe-in Toe-out. Assuming inflation is to spec...
  3. Jun 6, 2019 at 1:29 PM
    phabej
    I haven't got an alignment check, didn't need to cause it's a new truck. Aside from that, the dealership did a tire rotation at 5k with the oil change.
    I'm at 33psi up front, spec says it should be 30psi front, 32 rear? They are all 33's.
    EDIT: I do know that on certain stretches of road, I can feel the truck bounce a little, like there's groves on the road, but there's none, it's quite smooth. My wife's Subaru Ascent rides perfectly smooth on the same stretch of road.
    BTW, the REARS looks like it has perfect wear, but those were switch out not even 3k again with the tire rotation.
  4. Jun 6, 2019 at 1:40 PM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2023 Ford F-350
    Get your alignment checked.
  5. Jun 6, 2019 at 1:42 PM
    phabej
    Yep, just got off the phone with the local Toyota, scheduled for Monday. My tires thread life has just been shot shorter now. Sucks.
  6. Jun 6, 2019 at 1:45 PM
    15whtrd
    15whtrd Mr. Blonde
    These trucks kind of wallow in the corners anyways. Mine was doing this from the start. I promptly installed a sway bar and it is noticeably better.
    sundance, Rex Kramer and nlaroy like this.
  7. Jun 6, 2019 at 1:51 PM
    phabej
    I have the TRD sway bars (front/rear), mines the Sport edition.
    Any case, I also have 2 recalls to get done too, one is the front sensor and software update - getting all that done on Monday.
    Black Wolf and 15whtrd[QUOTED] like this.
  8. Jun 6, 2019 at 2:16 PM
    15whtrd
    15whtrd Mr. Blonde
    Yeah sounds like you might need an alignment. Those sway bars are pretty stiff surprised you’re getting feathering on the front tires.
  9. Jun 6, 2019 at 2:19 PM
    tundraal
    tundraal New Member
    I noticed the same thing on my truck (only has 2900 miles). The front end has never felt right to me. I think the alignment is out or something. I am going to get it checked at my 5000 mile service.
  10. Jun 6, 2019 at 2:21 PM
    JNeemus
    JNeemus New Member
    Arroyo Grande, CA
    2024 Tundra Limited
    Similar issue. I noticed the outside edge of my fronts were wearing pretty quickly. The rears still have very defined edges. I don’t know if I’m taking turns too fast or scrubbing the tires a lot during tight turns in parking lots. I normally drive pretty conservatively.
  11. Jun 6, 2019 at 2:25 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    I used to run 35 psi front/rear on all my trucks and cars since 1985. I ran 35 psi up front on my brand new 2017 4WD and soon noticed some edge roll/wear. I listened/read what others were doing and upped to 44 psi. That ended the problem.
  12. Jun 6, 2019 at 2:41 PM
    phabej
    Yeah it got worse in the last 3k miles. :bikewhoops: I did't buy a Chevy Shake truck here. :frusty:
    Yes, get it checked sooner than later. I don't know why a few of us are experiencing that, is it faulting from the factory? :annoyed:
    Me too, I don't do U Turns or a lot of agressive turning. I drive fairly light footed due our High Tech Gas Guzzling feature (kidding)of the Tundra..
    :notsure:
    Hmm 44 is pretty high and that's not within spec, I bet if I took it in at 44psi, they will say it's wrong and not do anything which will be not fix the problem.
    :turtleride:
    15whtrd[QUOTED] likes this.
  13. Jun 6, 2019 at 2:44 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    My 2nd gen had issues with that on OE bridgestones but never with any other model tire
  14. Jun 6, 2019 at 2:45 PM
    phabej
    hmm, but I doubt they will give new tires due to an issue with Bridgestone tires.
  15. Jun 6, 2019 at 2:46 PM
    ninjajay
    Spoolston, TX
    Bridgestone at the time gave me 25% off towards a new set. I bought Revos and they lasted basically to advertised mileage (45k, 50k advertised life). I had a lifetime alignment on that truck and it was always in spec on both sets.
  16. Jun 6, 2019 at 2:47 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    I should have noted that I'm on 275/60/20 Nitto Terra Grappler G2's.
  17. Jun 6, 2019 at 2:59 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    I would have the alignment check and printout you can view. I Think your psi is good. I have 10 ply tires with 80 psi max, which I run at 42 because they are heavy A/T and the truck seems to run better at that level. I am monitoring the tread wear, esp at the center and so far so good. These trucks are heavy so hard cornering will take a toll, but that doesn’t sound like an issue with you. (Are you the only driver?) I would rule out alignment before moving on to another issue.
    phabej[OP] likes this.
  18. Jun 6, 2019 at 3:28 PM
    malveman
    malveman New Member
    New jersey
    2022 Limited long bed MGM
    Get alignment checked and not by the lazer carp the dealer puts on the side of the truck u need a real alignment I went through that exact problem with my 2016. With 5000 miles
  19. Jun 6, 2019 at 3:35 PM
    Xtaco16
    Xtaco16 New Member
    2018 Tundra TRD sport
    This is happening on my 2018 limited OR too. Did the dealer say its normal?
  20. Jun 6, 2019 at 4:03 PM
    Tundra_Nitti
    Tundra_Nitti New Member
    Delaware
    2017 Silver Sky Tundra SR5
    I'm hoping to wear my tires out so I can get some new wheels and tires and justify it to the wife. I have 20k on the truck now but the tires are still at 7/32nds. Damn Michelins.
    To the OP. Alignments are under 12 month 12,000 mile warranty from Toyota. Just let the dealer know you would like a warranty alignment.
    WrigglingWilly likes this.
  21. Jun 6, 2019 at 4:04 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    I run BFG AT KO2s at 40 psi and have no problems of any kind with uneven wear [rotating every 5,000 miles]. I think some people run them at 45 psi.
    Anyway, the only issue with the KO2s is that I have a little vibration from 71-74 mph, which I have not been able to eliminate, so I just drive above or below that speed.
    Anyway, that's why I am going to Cooper tires next time: they won't wear as well, but they will ride better [especially the 10 ply] IMO.
  22. Jun 6, 2019 at 4:05 PM
    TundraDude18
    'Merica
    '21 Limited CM
    Wow. Great info. Thanks!:thumbsup:
  23. Jun 6, 2019 at 5:58 PM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    Free gold!!!
  24. Jun 6, 2019 at 7:03 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have the same problem. I noticed it at 3k miles. I had them check the alignment. Toe was factory off a little bit. They fixed it. At 6k miles now. Same problem.
    Wiscdave likes this.
  25. Jun 6, 2019 at 8:26 PM
    phabej
    Yes I'm the only driver. My wife won't drive my truck she says it's too big for her.
    I have scheduled it have it looked at Monday at the local Toyota dealership
    mambo143[QUOTED] likes this.
  26. Jun 6, 2019 at 8:26 PM
    phabej
    Ok I will, I'm 8 months in only.
  27. Jun 6, 2019 at 8:27 PM
    phabej
    Is this a reoccurring problem? That would suck
  28. Jun 6, 2019 at 8:29 PM
    phabej
    Hmm interesting how much did it cost you ? Did it solve it permanently? I would think so alignment should last a while. Not a few thousand miles.
  29. Jun 6, 2019 at 10:51 PM
    ZappBrannigan
    2018 1794 MGM
    NVS light bar
    My best guess is something is throwing off the toe. That’s what causes the feathering of the tire. I don’t know what though.
  30. Jun 7, 2019 at 4:00 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    It's those crappy bridgstone tires. I put Michelin defender Ltx on mine they've been fine
