Favorite postings - will it fit?
Discussion in 'Wheels & Tires' started by Geodude82, Feb 8, 2022.
  1. Feb 8, 2022 at 1:17 PM
    Geodude82
    Geodude82 [OP] New Member
    I know this is a favorite here, so I thought I'd add :)
    I have a 2019 crewmax, with a 3/1 leveling. I'm looking to put a little more rubber under her but I'm also thinking about saving the OEM wheels (I think they look pretty good).
    I'm not opposed to putting spacers on but only enough to get the rubber to flush or just slightly outside of the fenders, but not much, so maybe 1.25" spacers? But I also don't want to do any serious trimming.
    Here's my question, with my 3/1 level, and if I added 1.25 spacers, what would I be able to squeeze under?
    I'm thinking 295/70/R18, tell me otherwise!
    Thanks in advance!
  2. Feb 8, 2022 at 2:17 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    people have installed 295/70-18 on stock, unlifted trucks. So yes they will fit with a 3/1. UCA clearance is tight, about a pinky width but they can work fine with even stock wheels. 1 inch spacers may fit better, less chance for rub, vs 1.25 or 1.5. Those spacers are like changing to lower offset wheels, too low offset can cause rubbing on body mount, mudflaps, etc, but all that can be addressed.
    Lots of info in the suspension and wheel and tire forums here where people installed that size on 0-3 inch lifts.
  3. Feb 9, 2022 at 1:57 AM
    Geodude82
    Thanks! There is so much info on fitting that it is almost paralyzing, so figured I'd try anew.
    I've never seen 1 inch spacers, i though 1.25 were the thinnest we could go without having to change lugs.
