Favorite Mods
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by bruce213, Dec 24, 2019.
  1. Dec 24, 2019 at 1:12 PM
    bruce213
    bruce213 [OP] New Member
    Bruce
    2019 trd sport 4x4 crew cab
    Katzkin Leather, M2G DVD Player, Pioneer 8500NEX, 2" Spacers, Bigger Tires on Stock Rims, Undercover Flex Tonneau Cover, Bedrug, Tyger Fender Flares, Iron Cross Patriot Running Boards
    Whats everyone done to their 3rd gen? Looking to get some ideas. So far I've done leveling kit, tonneau cover, and aftermarket radio.
    Rica25 and PlatinumPro like this.
  2. Dec 24, 2019 at 1:29 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    pro grille, upgraded tires, upgraded fogs, upgraded headlights, lightbar, Bilstien 6112's + 5100's... that should get you started. Merry Christmas!
    MDHinSD, Tundyfundy and bruce213[OP] like this.
  3. Jan 3, 2020 at 10:48 AM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    20191006_160643.jpg 20191022_072709.jpg Ceramic coat. Helps protect from uv light, beads water right off, and makes washing it a breeze.
  4. Jan 3, 2020 at 1:55 PM
    Tzvia
    Tzvia Just an old woman in a pickup truck.
    Los Angeles County
    2019 5.7L Limited TRD Off Road 4x4
    Just a Bed Rug and Snugtop XTRA Vision
    Sometimes, it's the simple things... Replaced the front turn signals (which are almost invisible IMO) with LED ones, along with LED rear brake bulbs. Added an organizer to the center console (bought that and the LED bulbs from Amazon).
    Probably my two faves are the Go Rhino RB20 running boards and Cooper AT3 XLT tires.
    jewsNbrews likes this.
  5. Jan 3, 2020 at 2:04 PM
    GNTundra
    Gino
    2013 White
    That is one good lookin pickup Tim! :thumbsup:
  6. Jan 3, 2020 at 2:10 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    TRD Pro shift knob
    Feels great in the hand..
    784D9D9E-4CDA-4C26-A2C7-B47BBC9D66F7_zps_f0430943b3f32a274fd431d9fde005c92aa39083.jpg
    76BBB533-6F30-45AA-94FE-F8AF0B78454E_zps_15cfa4540a2e326fdfde1cbfd42011b0976d6d2d.jpg
    Big fan of the TRD Pro grille (with color matched letters) and black headlights.
    Pics were before my AMP steps.
    94B1C49A-A66D-4F31-99DA-6BD45F492426_zps_3a3bb0cdb7683d26a77ef343b9da7b7907d73491.jpg
    A495235D-606D-4C59-9082-06160A6F79D0_zps_4b792500f240c5b49e483b5d48a1de46fe8ed8df.jpg
    jewsNbrews and GNTundra like this.
  7. Jan 3, 2020 at 2:17 PM
    GNTundra
    Gino
    2013 White
    Id have to say wheels/tires.
    2nd gen :anonymous: :D
    Y0TA PR0, AKJ78, 15Yota and 1 other person like this.
  8. Jan 3, 2020 at 2:30 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Thanks Gino!
  9. Jan 8, 2020 at 9:58 PM
    ThePee
    ThePee New Member
    Loving the blue bud
  10. Jan 9, 2020 at 8:11 AM
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I've just added the color matched pocket flares, and yesterday installed the S.E.T. OEM W Drop Running Boards. I like the fact that they are compact, light weight, powder coated aluminum so hopefully they will stand up better to corrosion. Next on the list is 1.25" spacers and 35" tires, then a Diamondback black bed cover.
    ejes, Tundra805, RedDragon and 4 others like this.
  11. Jan 15, 2020 at 3:01 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    I’ve done a bunch, but my favorite has been the sprint booster same as pedal commander. Sway bars front and back second.
  12. Jan 15, 2020 at 3:06 PM
    Mickeydog
    Mickeydog New Member
    Dave
    West Michigan
    2015 Tundra Pro CrewMax
    Diamond back lid, 2019 Pro LED Headlights, Recon Smoked LED Tail lights.
    Were did you get the S.E.T. OEM W Drop Running Boards?
    Thanks, Dave
  13. Jan 15, 2020 at 4:00 PM
    TampaRD Pro
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    I purchased them from a local Toyota dealer here in SW Florida, but not the dealer where I purchased the truck. They were over a hundred bucks cheaper from this dealer than the other, and even cheaper than ordering them from Sparks (who also stocks them) once you factored in the shipping costs. I installed them in about an hour, taking my time and doing it by myself. Eight bolts each side all factory pre-drilled and tapped but the bolts on the drivers side are a size different from the passengers. They were clearly marked and separated in the box. I looked at a lot of different side step/running boards before deciding on these. I liked the fact that they are powder coated aluminum and tuck up close to the rocker panels. They certainly wouldn't be useful as rock sliders but then they aren't meant to be. I looked at the S.E.T. "OEM" Predators, too as the dealership where I purchased the truck had several lifted 2020 Tundras and Tacomas on the lot with both types installed.
    Part: W Drop Step Running Boards (00016-34787)
  14. Jan 15, 2020 at 6:44 PM
    PG94
    PG94 New Member
    Patrick
    Ohio
    2018 Quicksand Tundra Limited
    2019 TRD PRO Grill, Leveling kit, front and rear sway bars, TRD cold air intake, 18" black trd wheels, rigid ditch lights, cali raised ditch light mounts, Rock lights, TRD cold air intake, tri-fold bed cover, rhino lined bed lining, blacked out badges, remote start.
    Rigid ditch lights and rock lights on a 2018 Limited/TRD PRO Quicksand
  15. Jan 15, 2020 at 6:56 PM
    Nice. I dig how you color matched your tires, too! :thumbsup:
    Tundra805, Patch999 and Tundyfundy like this.
  16. Jan 15, 2020 at 6:57 PM
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    Morimito headlights and fog lights
    GasGuzzler and PG94 like this.
  17. Jan 15, 2020 at 7:58 PM
    PG94
    PG94 New Member
    Patrick
    Ohio
    I recommend one muddy cornfield and your tires will match your paint job too!
  18. Jan 15, 2020 at 8:07 PM
    AKJ78
    AKJ78 New Member
    Aaron
    San Diego
    2016 Silver Platinum 4X4
    3/1.5 lift. TRD sway bar. Bakflip V1 cover. Fuel wheels w/BFG A/T.
    Favorite mod definitely lift/tires/wheels. Pictured is my most recent mod. Tundradude34 dropped a video in early December showing off the wireless charger. 5 minutes later my order was in. I’ll admit it’s overpriced but I don’t really care. Super easy, super clean install.
  19. Jan 15, 2020 at 8:28 PM
    2chains
    2chains New Member
    Southern Ablerta
    Front window tint
    RedDragon and Tundyfundy like this.
  20. Jan 16, 2020 at 3:56 AM
    Mickeydog
    Dave
    West Michigan
    They say these will only fit the 2019 and 2020 models. I have a 2015, so I'll do a little more research. See why they won't fit mine.
    Thanks
  21. Jan 16, 2020 at 4:00 AM
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    Clazzio seat covers
  22. Jan 17, 2020 at 7:06 PM
    Redder
    Redder New Member
    North Georgia, USA
    2016 Tundra TRD Pro
    Driver Side grab handle mod Under rear seat storage Weather tech mats (they Suck) AJT alum shift handle AJT cup holder and shifter plates White knuckle sliders w/full diamond plate Carbon filter delete Tint Lug nut rubber caps Bed rug VLed inside VLed Footwells VLed day running lights Spyder Rear led tail lights Matte Black hood wrap 275/70/18 BFG AT KOs Ridgid Fog light (mod) -they weren’t included in ‘16 Light bar behind Pro grille Loud horn mod (my fav) LoPro roll up tonneau cover Nestar Edition Antenna Lettering inserts GP antenna terminals Coupe Battery tie down
    FAV mods
    White Knuckle Sliders...
    + VLed inside and outside
    jewsNbrews and Tundyfundy like this.
  23. Jan 17, 2020 at 7:09 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    On order...can't wait
    Redder[QUOTED] likes this.
  24. Jan 17, 2020 at 7:09 PM
    Redder
    Redder New Member
    North Georgia, USA
    2016 Tundra TRD Pro
    What’s that arm rest cup holder
    Details please!
    Tundyfundy[QUOTED] likes this.
  25. Jan 17, 2020 at 7:11 PM
    Tundyfundy
    Bay Area, CA
    My truck has the front bench seat. It seats 6. That armrest is stock one. It folds up for the 6th person to sit there. When I have less than 6 it folds down and has little compartments and cup holders.
    Redder[QUOTED] and GODZILLA like this.
  26. Jan 18, 2020 at 2:44 PM
    TundraBlack
    TundraBlack New Member
    Combo
  27. Jan 18, 2020 at 2:45 PM
    TundraBlack
    Yeah like those new drop steps
    Tundra805 and jewsNbrews like this.
  28. Jan 21, 2020 at 8:43 AM
    19TRDPRO_FL
    19TRDPRO_FL New Member
    Paul
    Parkland, FL
    2019 Tundra TRD Pro
    Audio: Pioneer 8200NEX Infinity Kappa complete speaker package 4 Channel Kenwood amp 5 Channel Kenwood amp 10 inch JL Audio W1 shallow mount sub X 2 Readylift Pro Plus 4in lift (6 total) 22x12 Fuel Sledge wheels 35x12.5R22 Nitto Ridge Grapplers LED bar in hood scoop LineX step rails
    My favorite would be full stereo system replacement..
    - Dasaita 10.2 in head unit
    - Infinity Kappa components front and rear
    - JBL GTO 3.5in dash speakers x3
    - Two kenwood amps (under front seat and rear)
    - Line X coated dual 10in subwoofer ported box
    - Two JL Audio 10W3 sub's
    - Full sound deadening throughout the cab
  29. Jan 27, 2020 at 8:09 AM
    Rlh.airborne
    Rlh.airborne New Member
    2020 Mesquite Tundra TRD Limited
    That lift looks perfect not too much or too little, what is it and any issues after or during the install
  30. Jan 27, 2020 at 9:47 AM
    Vector W8
    Vector W8 Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Supercharger. By far my favorite mod. TRD Grill and many other mods follow.
    ZappBrannigan and jewsNbrews like this.
