Favorite Apps
Discussion in 'General Tundra Discussion' started by Royalpeeps, Nov 7, 2016.
  1. Nov 7, 2016 at 3:28 PM
    Royalpeeps
    Royalpeeps [OP] Awesome!!!
    Chad
    2017 Blazing Blue Pear Tundra SR5 TRD Package
    20" Fuel Vapor wheels 35" Toyo A/T II Tires 3 inch Toytec Boss kit with SPC UCA NFAB Wheel to Wheel Black Textured Nurf Bars OCD Center Storage Organizer and tray
    So what are some of your favorite phone apps that you use for your truck? I saw where someone was mentioned Fuelly in another thread. Any others that are like this that I should be using or are just fun to use to track stuff for your truck?
  2. Nov 7, 2016 at 4:52 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    All I need is Tundras.com :thumbsup:
    I have a relatively short commute, so no need to track or look at anything else. But if what I know about this forum is true, I'm about to learn something soon . . .:popcorn:
    462Loadtoad and zcarpenter92 like this.
  3. Nov 8, 2016 at 10:55 AM
    Royalpeeps
    Chad
    Really? No one uses any apps on your phone to track things on your truck? Guess I'm gonna try Fuelly. I have used a speedo app to see how messed up my speedo was once I got my lift and bigger tires. Not as bad as I thought. About 3-4 mph off at around 60.
  4. Nov 8, 2016 at 6:46 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I've used Dash Command for my previous truck, and will use it for the Tundra eventually. I use a WIFI OBDII connector. If you buy one, get one with a power switch so the transmitter doesn't burn out. My first one did. Also, get an extension cable and place it where it's easy to turn on and off.
    http://www.palmerperformance.com/products/dashcommand/
