Fastener Sizes
Discussion in 'Recovery & Gear' started by Timx9595, Jul 25, 2023.
  1. Jul 25, 2023 at 5:52 PM
    Timx9595
    Timx9595 [OP] New Member
    Connecticut
    2020 Black Tundra Crewmax SR5
    I’m looking to put together a tundra specific tool kit so I stop hauling around a ton of junk I don’t need. Does anyone have a list of all the fastener sizes that come stock on a tundra?
  2. Jul 25, 2023 at 7:30 PM
    Roborob70
    Roborob70 New Member
    Robert
    18 Toyota Tundra TRD
    1 10 mm wrench and 1 10 mm socket is the only thing you need!!!!!
    NewImprovedRon and bulldog93 like this.
  3. Jul 25, 2023 at 10:44 PM
    Roborob70
    Robert
    On second thought make that 2 10 mm sockets, it is inevitable, you will lose 1 socket, gotta have a spare...
  4. Jul 25, 2023 at 11:15 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    What I’ve remembered using…
    8,10,12,14,17,19,21,22,24,27,30,32mm 6/12pt
    39mm 12 point
    4,10mm hex
    T55 torx
    There may have been a 15 mm there somewhere, I think body mounts or something…just remember to carry any SAE necessary to cover not OE components you may have bolted up to the truck.
    AZBoatHauler likes this.
  5. Jul 25, 2023 at 11:25 PM
    blenton
    blenton New Member
    In MM… 8, 10, 12, 14, 15, 17, 19, 22, 24, 27. Axle nut is a bigger 39mm 12 pt if you think you might be needing to seal CV’s trail side. Also, the factory lugs use a 22mm socket but can swell if abused (or simply by running them down with an impact) so a 23mm socket is also advised even though I can’t think of anything else that actually uses it.
    Else, standard stuff like MM hex keys, assortment of screwdrivers and pliers, breaker bar and or cheater bar, magnetic pickup tool, zip ties, slim Jim kit, flux capacitor, 10’lb sledge, combination AK 57 oozie radar laser triple-barrel double-scoped hit-seekin shotgun…
    Hope that helps.
  6. Jul 25, 2023 at 11:27 PM
    AZBoatHauler
    So.Arizona
    7/8” works well for the swollen nuts too.
    blenton[QUOTED] and BiggHertz like this.
  7. Jul 25, 2023 at 11:28 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    you know how to handle them swollen nuts
  8. Jul 25, 2023 at 11:29 PM
    AZBoatHauler
    So.Arizona
    SD Surfer and BiggHertz[QUOTED] like this.
  9. Jul 25, 2023 at 11:35 PM
    AZBoatHauler
    So.Arizona
    Cruiserpilot and Cruzer like this.
  10. Jul 26, 2023 at 4:05 AM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    This is the year 2023. A cell phone is all the tools you need.
    NewImprovedRon likes this.
  11. Jul 26, 2023 at 4:19 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Probably a cell signal booster too if u adventure
  12. Jul 26, 2023 at 9:32 AM
    blenton
    blenton New Member
    It’s still pretty easy for me to find myself without cell service or without tow service. I just tell the mrs where I’m headed and when I think I might me back - kind like we did when cell phones weren’t a thing. If I miss that time by more than 12 hours, she might send somebody to look for me..
  13. Jul 26, 2023 at 9:38 AM
    AZBoatHauler
    So.Arizona
    Unfortunately there is no cell service the majority of the places I’ve been off-roading. Northern AZ is bad, SW Colorado / Navajo land is terrible. You can drive nearly an hour on a state highway without any signal. I have a radio with repeater info saved on my phone for offline access. Not perfect but worth the $ IMO.
    blenton likes this.
  14. Nov 3, 2024 at 9:33 AM
    Michael Tregre
    Michael Tregre New Member
    '14 Tundra SR5 CM
    Notta
    Some people leave the areas designed for plebs! Even if that isnt you, never expect someone else to rescue you.
