Fast Wireless Charging - Not enough power?
Discussion in '2.5 Gen Tundras (2014-2021)' started by odin1701, Feb 9, 2022.
  1. Feb 9, 2022 at 7:39 AM
    odin1701
    odin1701 [OP] New Member
    2021 Tundra LTD TRD OR MGM
    I have a charging pad that is capable of fast wireless charging. I confirmed it with a plug in charger in my house. It will not do fast wireless charging in my truck though. I tried a couple different 12V chargers. One that says it has 18W which should be enough for the 10W fast charging on my phone. It's an Anker adapter, so not some cheap junk. Has anyone had luck getting something to work? I'm wondering if there just isn't enough power from the cigarette adapter somehow?
  2. Feb 9, 2022 at 2:02 PM
    sharkmango
    sharkmango New Member
    2014 Tundra TRD 4x4 White
    :cool:
  3. Feb 9, 2022 at 2:12 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My math may be way off here, but P=IV results in 840mA no? Isnt the outlet fused at like 10 or 15amps?
  4. Feb 10, 2022 at 8:36 AM
    bosscib
    bosscib New Member
    PA
    2023 TRD Pro
  5. Feb 10, 2022 at 8:45 AM
    odin1701
    I was hoping it would work as I hate having to plug in if I don't have to. I usually don't lose too much with regular wireless charging, but I'll be doing the wireless android auto thing soon and I figure that will drain battery more. It's just nice to be able to keep topped off on longer road trips. I can always plug in if I have to.
  6. Feb 10, 2022 at 12:02 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Does the adapter support their fast charge power standard IQ3? Or Quickcharge?
  7. Feb 10, 2022 at 12:05 PM
    odin1701
    It says 18W power delivery so...
  8. Feb 10, 2022 at 2:06 PM
    Saltyhero13
    What is the make and model of both the charger and the adapter?
  9. Feb 10, 2022 at 2:11 PM
    odin1701
  10. Feb 10, 2022 at 2:14 PM
    Saltyhero13
    Neither port fast charges? Some USB-Cs aren't compatible with certain wireless chargers.
  11. Feb 10, 2022 at 2:20 PM
    odin1701
    Yeah neither one will. The charging pad is an Anker as well, and I know it will fast charge at least off of another adapter I have from a power outlet in my house.
  12. Feb 10, 2022 at 2:26 PM
    Saltyhero13
    Understand. That eliminates the pad and the phone from the equation. You can connect directly to the adapter to "prove" it fast charges thus eliminating the adapter as the issue. So either a mismatch between device and adapter or its the cabling.
    From Amazon for one of the Anker wireless pads (I have this one at home and office):
    Does NOT accept USB-C input
    Reviewed in the United States on August 4, 2021
    Verified Purchase
    Despite the product photos here showing the pad connected to a USB-C to USB-C wall charger (the photos definitely show it connected to a USB-C Anker wall charger), it in fact uses a USB-A to microUSB input. The description does not convey this clearly at all. Luckily I was able to dig up an old charger that is able to supply 9v and a microUSB cable. With these charging pad does in fact work as expected. It needs to be made much much clearer in the description that it does not accept USC-C, and the photos need to reflect that.
  13. Feb 10, 2022 at 2:28 PM
    odin1701
    Yeah I tried with the cable that came with the charger pad first. The same cable works with the wall outlet adapter. Then tried the USB-C. Wattage wise, it should provide enough.
  14. Feb 10, 2022 at 2:39 PM
    Saltyhero13
    I don't disagree. From the raw numbers you would expect it to be so and work with no issues. The user in the review is reporting it isn't working that way in that specific configuration.
  15. Feb 10, 2022 at 3:15 PM
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Maybe you have a bad device, or weak cig lighter?
    I find the stock wireless charge pad in my dads Tacoma is extremely sensitive to exact placement and phone covers of any thickness, with his latest model iphone anyway.
    I have a Samsung Note 8 and use this and get fast charging just fine Qi Car Vent Mount & Charger | MagicMount Pro Charge Vent (scosche.com)
    Mounted to this Toyota Tundra Center Dash Mount | ProClip USA
    And it works awesome.
    I also power it from a fast charge rated dual port usb adapter in the cig lighter. Got those usb adapters on both front cig lighters actually.
    Amazon.com: Hussell Car Charger Adapter - Fast Charge, Mini, Aluminum, Portable 3.0 Car Chargers with Dual USB Ports - Compatible with iPhone 13 12 11 Pro Max XR XS, Galaxy S21 10 9 : Cell Phones & Accessories
    Full details, I do have a slim semi soft plastic cover on my phone and I have the metal plates on the phone itself inside the cover.
    It holds fine for daily driving but falls when offroading, washboard dirt road vibrations etc, or if I drive to fast on the beach lol.
    If you mount the metal plates on the outside, it will hold real good, I just prefer a smooth phone front and back.
    Works for me because I hate cup holder, suction, or vent mounts, and prefer the phone in line of sight while driving for safety.
  16. Feb 10, 2022 at 3:22 PM
    odin1701
    I tried it on both the cig lighter inside the center console and the one on the lower dash area, same thing. I might just try a different car charger, but I can plug in from the charger via a cable and it will fast charge my phone so it's very odd.
    If you are able to get a fast wireless charger going then I don't see how it could be something with the cig lighters, that's odd.
  17. Feb 10, 2022 at 5:34 PM
    thearborbarber
    thearborbarber New Member
    SoDak
    2018 Tundra SR5
    I found a couple of those adapters say they are 18watts but it's 18 watts total, leaving each port at 9 watts a piece. I could not find that in the link you provided however but food for thought.
  18. Feb 10, 2022 at 5:35 PM
    odin1701
    The one I have says 30W spilt 18W on the USB-C and 12W on the other.
  19. Feb 10, 2022 at 6:01 PM
    thearborbarber
    SoDak
    2018 Tundra SR5
    That answers that.
    Rocko9999 likes this.
  20. Feb 10, 2022 at 6:24 PM
    Saltyhero13
    Its not the adapter then if you can fast charge wired. You can try a different cable make and length but I doubt it is the issue.
    It could be a filter in the wireless pad that is interfering with the charge rate. If I'm not mistaken its going from 12V(truck battery) to 5V(adapter) to AC(wireless); probably not a clean 5V going to the pad. It is either getting filtered before getting converted to AC or the inverter doesn't like the unclean 5V. Without a schematic for both it would be hard to tell what is causing this issue.
  21. Feb 11, 2022 at 10:45 AM
    odin1701
    Well...it was somehow the adapter. I got a new adapter and put it in. It's now fast wireless charging with that one. Doesn't make sense but whatever.
    Maybe the 12W wasn't quite enough on the USB-A port and the charger pad didn't like the USC-C one. The new one I got is 18W each port with two USB-A. I just moved the other one to the front dash location so I can charge USB-C to USB-C if I need the super fast wired charging.
    Saltyhero13 likes this.
