Fan clutch going out?
Discussion in '1st Gen Tundras (2000-2006)' started by Jake92, Jul 12, 2020.
  1. Jul 12, 2020 at 12:09 PM
    Jake92
    Jake92 [OP] New Member
    2000 Toyota Tundra SR5 4x4 TRD
    So yesterday I got the brake master cylinder fixed so I decided to go off roading and after a bit it sounded like my engine was roaring, very loud with the engine rpms like the fan. Almost sounded like a diesel truck when they are loud. Anyway I was wondering if the fan clutch is going bad and exactly what I need to fix it and take it apart. It was very hot day yesterday so that might be why? It only roars really when I am off roading in the heat over 100 degrees on the freeway it sounds normal. Thanks
  2. Jul 12, 2020 at 12:16 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Sounds like it's doing what it's supposed to.
  3. Jul 13, 2020 at 10:32 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Yeah, if your fan clutch goes out you'll know it. It makes really bad metal on metal sounds.
    YardBird and Jake92[OP] like this.
