Family of 4 Tonneau Cover w/ RTT
Discussion in 'Tonneau Covers, Caps and Shells' started by Jg619, Jan 6, 2024.
  1. Jan 6, 2024 at 12:21 PM
    Jg619
    Jg619 [OP] New Member
    24 Platinum TRD 6.5 bed
    Looking for helping narrowing down my options to find a suitable combination for weight/distribution as well as features.
    Looking for a tonneau cover, low profile cross bars able to hold a 4 person RTT ikamper skycamp 3.0 as an example.
    I think retrax is out of the question due to the weigh restriction
    RTT will not always be on vehicle
    But narrowed it down to a diamondback+bars combo
    Or a Peragon+Billie bars combo
  2. Jan 6, 2024 at 2:14 PM
    BIGUGLY
    Paul
    2018 Limited
    Could look at Kb voodoo
  3. Jan 6, 2024 at 2:24 PM
    RobertD
    Robert
    DFW, Texas
    If you need to open the cover while the bed is loaded, you can't with the Peragon. Its a good idea for a cover but poorly executed. Search them on the forum and you will see the threads where folks have had fitment issues as well.
    Diamondback is pretty bulletproof. If you plan to keep the truck a bit, they are probably worth the investment for your needs.
  4. Jan 7, 2024 at 8:01 AM
    Jg619
    Anyone have experience with a retraxpro MX and using the factory rails for a crossbar mount?
    Billie bars says it will work, that way they truck is supporting the weight vs the cover
  5. Jan 7, 2024 at 8:03 AM
    TexasTacoma713
    TexasTacoma713 New Member
    2023 SR5
  6. Jan 23, 2024 at 12:32 AM
    Corsa1
    Corsa1 New Member
    2021 Cavalry Blue Crewmax
    What TexasTacoma713 said. Currently I am planning a RetraxPro XR with an UptopOverland Full Height TRUSS Rack that integrates with the rails. That seems to be the best combination while still utilizing the bed and rear drop window when camping. And you can add some Total Chaos Bed stiffeners just in case for the added weight. RTT should be no problem on that rack combo.
  7. Mar 4, 2024 at 8:48 AM
    SD Surfer
    Bruce
    So Cal
    Holy Taj Majal Batman!
    Since I tow my tiny house behind me I am admittedly clueless about RTT's, but I had no idea there were units big enough for 4 people!
