Faint whistle or chirping sound when accelerating
Discussion in '2.5 Gen Tundras (2014-2021)' started by bsavoir, Oct 13, 2018.
  1. Oct 13, 2018 at 4:28 PM
    bsavoir
    bsavoir [OP] New Member
    Killeen, TX
    2016 Tundra Limited CM 4x4
    Gibson Metal Mulisha Exhaust, Replaced bulbs w/ LED's, AFe intake, Bullydog Tuner, Aftermarket Audio system, Rhino Bed Light sports bar, Tonneau Cover, Spyder Auto Headlights and Taillights, Recon 3rd Brake Light, Kensun HID's, Fender Flares, Custom Leather Interior, Heated Seats, 5% Tint on the Rear Windows, Pod light Foglights, 31" light bar behind the grille, linex spray bedliner, linex sprayed grille, ditch lights w/ dual 3in LED pods, 60" Tailgate LED strip.
    I have noticed this for a bit now, whenever I accelerate I hear a faint whistling or chirping sound but as soon as I let off its gone.
  2. Oct 13, 2018 at 4:41 PM
    womprat57
    womprat57 BABE the Big Blue Ox
    NH
    2014 SR5 DC 4x4
    I get similar, like a faint coil whine going from 2nd to 3rd, curios what will turn up on this.
  3. Oct 13, 2018 at 4:49 PM
    Moon Puppy
    Moon Puppy I'm not new!
    Bob
    South Carolina
    2020 Tundra Limited
    Bad ground on something electronic?
  4. Oct 13, 2018 at 4:53 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    I have a new 2018 and have noticed the same. It seems more pronounced when the truck is cold. Kind of like a faint belt slipping squeal or a heat shield vibrating at high frequency.
    It really reminds me of a heat shied resonating at high frequency.
    Any TSB's out there?
  5. Oct 13, 2018 at 5:44 PM
    bsavoir
    Killeen, TX
    Not electronic, I don't hear it with the windows up or when the volume is up and no music plays. Just when there down. Most of the time can drown it out with music but times when I don't listen to it I hear it again.
  6. Oct 13, 2018 at 5:48 PM
    Rica25
    Ricardo
    Tulare
    Have u guys replaced the stock engine filter? With aftermarket?
  7. Oct 13, 2018 at 6:01 PM
    AndyCBR
    AndyCBR New Member
    Baton Rouge, LA
    OEM filter 5k miles. Been hearing this since day one. Mostly at 2k rpm just before shifts. As I said before it seems to be more pronounced when the engine is cold.
    Almost like a whistling noise for 1-2 seconds just before the shift from 2-3 and 3-4.
    I kind of figured it was just a characteristic of the engine or the heat shields vibrating until the entire system gets up to full operating temperature.
  8. Oct 13, 2018 at 6:21 PM
    BIGUGLY
    Paul
    2018 Limited
    Probably the wire filter before the throttle body. It creates a whistle at tea under acceleration. It is normally more pronounced with a high flow air filter. You can replace the wire filter gasket thing with just a gasket and it goes away.
    Sumo91 likes this.
  9. Oct 13, 2018 at 7:17 PM
    bsavoir
    Killeen, TX
    I do have a afe intake, I don't recall hearing when first installed it, but maybe it was just never pay to much attention.
  10. Oct 13, 2018 at 7:45 PM
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    Watched a video recently of a screen being removed in the throttle body that causes the low rpm whistle
  11. Oct 13, 2018 at 8:04 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I get a pretty loud whistle/screeching sound when I turn off the nannies and press the accelerator in an aggressive fashion from a dead stop ......I thought that was normal.
    :burnrubber:
    15whtrd likes this.
  12. Oct 14, 2018 at 5:43 AM
    womprat57
    NH
    2014 SR5 DC 4x4
    Just a K&N drop in filter here.
  13. Oct 14, 2018 at 5:45 AM
    womprat57
    NH
    2014 SR5 DC 4x4
    HAHAHA yeah thats happened a few times, but i think I got that one figured out :bananadance:
  14. Feb 23, 2020 at 2:23 PM
    TundraPro15
    TundraPro15 New Member
    Is the throttle body gasket. There’s threads that explain it better. $10 and 10 min of time and fixed
