faint horn
Discussion in 'General Tundra Discussion' started by Brandenmontoya10, Oct 4, 2016.
  1. Oct 4, 2016 at 7:10 AM
    Brandenmontoya10
    Brandenmontoya10 [OP] HE > I
    Branden
    2011 Tundra Charcoal Grey
    What's up fellas! So both of my horns on my 2011 Tundra have gone extremely faint. If I was 30 feet away you would probably barely be able to hear them. And it's BOTH. If I unplug one and press the horn both make the same faint wounded horn noise with the other unpugged. Any suggestions? The fuses is fine and I was unable to find the horn relay!
  2. Oct 4, 2016 at 7:21 AM
    buckeyes1975
    Kevin
    OH-IO
    2008 Limited Double Cab
    Could it be water? I had it happen to my 4runner once after pressure washing the bugs off the front grille. Dried out in a day or so never had an issue again.
  3. Oct 4, 2016 at 7:33 AM
  4. Oct 4, 2016 at 8:53 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Proper ground?
    ColoradoTJ likes this.
  5. Oct 4, 2016 at 4:23 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Possible poor connection between relay and horns, bad ground, bad contacts in horn relay
  6. Oct 4, 2016 at 7:44 PM
    This OP^^^. I would take the bolts off that attach the horns to the front, make sure they are not rusted and reinstall.
    Let us know.
  7. Oct 4, 2016 at 8:30 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Really not much louder at all
    NewImprovedRon likes this.
  8. Oct 5, 2016 at 8:16 AM
    Brandenmontoya10
    Branden
    Do you happen to know where the relay is located?
  9. Oct 5, 2016 at 11:46 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    I've never looked for it but on the 2nd Gen I believe it's in the underhood fuse panel.
  10. Oct 5, 2016 at 11:49 AM
    Brandenmontoya10
    Branden
    I looked under the hood in the fuse box and was unable to find it. Just the 10amp fuse
  11. Oct 5, 2016 at 11:56 AM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    The underside of the fuse panel cover has a diagram that shows where the relay is.
