Faint engine tick/knock
Discussion in 'General Tundra Discussion' started by Ronskii06, Apr 14, 2020.
  1. Apr 14, 2020 at 6:56 PM
    Ronskii06
    Ronskii06 [OP] New Member
    I just purchased my first tundra. It’s a 2016 5.7 with 75000 miles and I can’t help but notice a slight tick or knock much like a diesel would make. It’s very faint but enough that I hear it. I hear it mostly in the cab of the truck and underneath behind the engine and in the exhaust.
    is this normal? Am I paranoid or should I be concerned?
    My previous truck hand a loud exhaust and all kinds of noises so when this nice quiet tundra it stands out to me
  2. Apr 14, 2020 at 8:37 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I've got a '15 5.7, it is very quite at idle, I mean there are lots of moving parts in there so there may be a 'tick' but no knocks. Maybe you can post an audio file for folks to listen to?
  3. Apr 14, 2020 at 8:42 PM
    Ronskii06
    They probably wouldn’t be able to hear it lol
  4. Apr 14, 2020 at 8:50 PM
    Johnsonman
    Austin
    Sequoia
    Well then it probably zero problem, just a quiter exhaust so other sounds are more noticeable.
    Depending on how one feels about oil additives, I've used several different Liqui Moly products. This one aims to quite engines down: https://www.amazon.com/Liqui-Moly-2...586922379&sprefix=liqui+m,aps,196&sr=8-2&th=1
    I also use another Liqui Moly product, Ceratec, it added 4/10 of an mpg to my 5.7, not much but i like the idea things are spinning more freely in there, haha. Luck with all things.
  5. Apr 14, 2020 at 8:53 PM
    ChrisTRDPro
    ChrisTRDPro New Member
    MT
    2017 Tundra TRD Pro CM
    loose heat shield? if you hear it more underneath than you do in the engine bay, that's what I would check.
  6. Apr 14, 2020 at 9:25 PM
    docfnky
    docfnky New Member
    Sounds like the 5.7 doing it’s thing.
    Trooper2, 08crewmax, TILLY and 2 others like this.
  7. Apr 14, 2020 at 9:47 PM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Welcome to all Toyotas and Lexus
    Trooper2, Larly5000 and Ronskii06[OP] like this.
  8. Apr 15, 2020 at 9:08 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    #tickoflife
  9. Apr 19, 2020 at 6:42 PM
    ToyoOperator139
    ToyoOperator139 New Member
    2014 Platinum
    I have a 2014 I believe is a flex fuel engine and hear the same thing. I also notice what I think is an exhaust manifold leak on cold starts when it's in the 20's or colder. It sounds like a loud knock for 1-3 seconds, I mean LOUD. I know dodge hemi has been known for that same issue. I heard it while test driving a brand new ram a few years back. If it is the exhaust has anyone had this issue? Has anyone put a set of long tube headers to fix this issue?
  10. Apr 19, 2020 at 8:48 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    Normal sound for this 4 cammer engine. Run 5w-20 or 5w-30, and things will quiet down slightly, but really nothing to worry about.
    TILLY likes this.
