Failed parking assist
Discussion in '2.5 Gen Tundras (2014-2021)' started by Loft boss, Nov 22, 2020.
  1. Nov 22, 2020 at 6:13 PM
    Loft boss
    Loft boss [OP] New Member
    2018 tundra limited 4 x4
    Just purchased. LED cargo lights
    Just purchased a 2018 tundra limited. Power washed the cargo box and now the parking assist has failed. The sensors did get wet but not direct pressure from the wand. Any one have this repaired?
  2. Nov 22, 2020 at 6:15 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Wait for it to dry and re-evaluate...90% of time it just needs to dry...
    Saltyhero13 likes this.
  3. Nov 22, 2020 at 7:45 PM
    Loft boss
    I will give it a sunny day
    HulkSmurf14 likes this.
  4. Nov 22, 2020 at 7:45 PM
    Loft boss
    Post tomorrow
  5. Nov 22, 2020 at 10:08 PM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    Did you by chance turn the switch off? It’s common when doing an interior clean.
  6. Nov 23, 2020 at 8:11 AM
    Loft boss
    parking assist is still not working. It is not a thing I really need but my fiancé may use it to park the truck in town. I just bought this truck so the fact that one thing is failing is a bummer.
  7. Nov 23, 2020 at 5:52 PM
    KingsAustin
    KingsAustin Grey Goose II
    Morgan County, AL
    2021 Limited Night Shade
    BakFlip MX4, Gator All Weather mats, Console Safe, Ceramic Tint, Roadmaster Active Suspension, Interior/exterior LED conversion, Wireless console charger, AJT designs.
    Did you check your fuses?
  8. Nov 23, 2020 at 5:56 PM
    Ckatz53
    Ckatz53 Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Toss it in some rice! In all seriousness, I've washed my truck a million times and have never had this issue. Both my front and rear sensors are relatively exposed (running SS Built bumpers that position the sensors in the open essentially). Sounds like another issue is present. I'd check a fuse, or maybe you bumped the parking sensor button, both mentioned above.
  9. Nov 23, 2020 at 7:18 PM
    Loft boss
    Total malfunction. I can turn it on and it displays the sensors location with an X inside a circle. Does not pick up anything in front of the sensors. I will look for the fuse.
  10. Nov 23, 2020 at 8:41 PM
  11. Dec 10, 2020 at 9:01 AM
    Loft boss
    Dealer replace the bad senor mid left on the rear bumper. they had to take the bumper off to get the job done.
