Factory xm satellite with aftermarket head unit
Discussion in 'Audio & Video' started by rubberchicken48, Aug 28, 2020.
  1. Aug 28, 2020 at 2:16 PM
    rubberchicken48
    rubberchicken48 [OP] New Member
    2016 Toyota Tundra SR5, Black
    Pioneer HU and storage under the back seats
    For anyone that has upgraded their entune non JBL to an aftermarket HU, were you able to use the factory xm satellite connection or did you have to buy a whole new tuner?
    ATHiker likes this.
  2. Sep 24, 2020 at 5:39 PM
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    I just ordered a new head unit from tech12volts and received it today. It came with adapters for the factory nav antenna, factory satellite antenna, factory USB adapter. While the head unit is "SiriusXM Ready"; it just means it has the port on the back to accept the antenna connection. So I had to order the SiriusXM sxv300 receiver on top of it. It’s about $50
  3. Sep 24, 2020 at 5:54 PM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    You can use the factory antenna, but you will need an xm tuner regardless. The tuner is built into the oem headunit. So removing it requires a tuner with an aftermarket headunit.
  4. Sep 25, 2020 at 4:01 AM
    ezdog
    ezdog New Member
    Gateway To The West
    The XM tuner is NOT built in to the OEM head unit.
    It hangs under it and is easily removable as I did with mine to switch it from one OEM radio to another higher end and newer unit that I bought as an upgrade in my truck.
    Now I am not sure that it can be used with any aftermarket radios either but it is sure not built in to the radio as they come from the factory either.
    I suspect that you can not easily find the adapters needed to make this work and I also have always found the aftermarket tuner for free or really cheap when I have needed one as long as you pay for three months of service in advance and usually bought at Best Buy.
    They are really more after the monthly recurring revenue more than any small money they make selling the hardware and so the tuners are deeply discounted a lot of the time.
    In this terrible pic the radio is upside down on my bench and the Sat Tuner is on the top opposite how it will be under the radio when mounted in the truck.
    It should be clear that it is a seperate unit and is just hung under and connected to the factory radio.
    panicman likes this.
  5. Sep 25, 2020 at 4:22 AM
    Danman34
    Danman34 New Member
    Danny
    Ok. Either way, the factory tuner sucks and limits the amount of stations you actually receive. The actual SiriusXM tuner is only $30 and plugs directly into any aftermarket unit. Why would you even bother trying to adapt the “stock one”?
  6. Sep 25, 2020 at 4:53 AM
    ezdog
    ezdog New Member
    Gateway To The West
    Agreed which is pretty much what I said but I also had the need to reuse the factory tuner in my truck and better clarity about the actual factory setup might help someone else down the road.
  7. Nov 16, 2020 at 10:51 AM
    tightywhitey
    tightywhitey New Member
    New Orleans, LA
    2015 Toyota Tundra CREWMAX - Louisiana Edition
    Does an existing XM subscription have to be updated if a new tuner is installed or is it tied to something else?
  8. Nov 16, 2020 at 10:59 AM
    irishpride114
    Travis
    Kinda. As soon as I registered my new headunit; I had to pay a small processing fee
  9. Nov 16, 2020 at 11:01 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    When I upgraded my 2008 JBL HU to a 2010 JBL HU (in my prior truck), the tuner was integrated into the HU and not a separate bolt-on part. So it likely depends on the year and specific HU as to whether it is separate or built-in.
    You log into your account and transfer the subscription over to the new unit. Yes, they typically charge you a fee to do that. :censored:
  10. Nov 16, 2020 at 12:35 PM
    ezdog
    ezdog New Member
    Gateway To The West
    You are correct I should have been more specific that the 3rd gen radios have a seperate tuner.
    RainMan_PNW[QUOTED] likes this.
  11. Aug 25, 2022 at 1:14 PM
    JDavis.hondatech
    JDavis.hondatech New Member
    Jake
    2019 Red TSS
    TSS package, pro grill and headlights
    Where would I buy this adapter? And what would it look like. I have aftermarket stereo and just purchased the Sirius tuner but would rather adapt the to factory antenna instead of running an additional one to the roof.
  12. Aug 25, 2022 at 1:33 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    iDatalink ACC-SAT-TO1 sTO1 Satellite radio antenna adapter: connect the factory satellite radio antenna to a SiriusXM tuner in select Toyota models at Crutchfield
    Amazon.com: MAESTRO Acc-SAT-TO1 Satellite Antenna Adapter Compatible with Toyota : Electronics
  13. Aug 25, 2022 at 3:22 PM
    irishpride114
    Travis
    For what it’s worth you can run the new antenna in the dash and it still work. I mounted mine just in front of the center speaker; but still under the grill. Had to make a small notch so everything sat flush.
