Factory Subwoofer
Discussion in 'Audio & Video' started by Gil17SR5, Oct 7, 2020.
  1. Oct 7, 2020 at 8:57 PM
    Gil17SR5
    Gil17SR5 [OP] New Member
    2017 Dark Gray Tundra 4X4
    Hello all newby here! I just bought a 2017 tundra sr5 and I'm pretty sure it has a small subwoofer somewhere because it has an amp under the passengers seat and a little bit of bass to it. Where is the factory sub mounted? thank you for your help!
    G.
  2. Oct 7, 2020 at 9:11 PM
    Kybosh_ag
    Kybosh_ag New Member
    Adrian
    2008 SR5 DC
    Not enough
    The JBLs have an 8" sub. If it's a DC, it's under the driver's side rear seat. I believe the CMs have them behind the rear seat.
  3. Oct 7, 2020 at 9:14 PM
    Shelbie67
    Shelbie67 New Member
    Blake
    NorCal
    2018 tundra crewmax platinum
    RADFLO 2.5 suspension, apex rock sliders, BFG KO2, exhaust delete, Full Active Stereo
    Unless your headunit says “JBL” you do not have a factory sub. Some tundras have an amp for door speakers is all
  4. Oct 7, 2020 at 9:24 PM
    Gil17SR5
    ok thanks for your replies, but that sure is a lot of bass coming out of those little speakers, for there not to be a sub.
  5. Oct 7, 2020 at 9:29 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    That factory amp powers the door speakers.
    The dash speakers run straight off the HU
    I doubt your SR5 has a JBL system.
    As @Shelbie67 stated, JBL would be on your radio, and possibly the doors, if you had it.
    There are a ton of threads about the underseat factory amp.
    Welcome to the forum..
  6. Oct 7, 2020 at 9:30 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Did you find one under or behind the rear seat?
    Do you have a double cab or crewmax?
    Since you bought it used, it is possible someone replaced door speakers or added a sub to your truck.
  7. Oct 8, 2020 at 7:41 AM
    Gil17SR5
    It’s a crewmax. I think you are correct the previous own had a little sub installed somewhere. It definitely has more bass than those little door speaks can make.
    and why do the back door panels have tweeters but no tweeters up front? Odd!
  8. Oct 8, 2020 at 7:58 AM
    Shelbie67
    Blake
    NorCal
    Because you have dash speakers.
