Factory Remote Start Installed by Dealer
Discussion in '2.5 Gen Tundras (2014-2021)' started by TeamGoose, Feb 21, 2020.
  1. Feb 21, 2020 at 3:44 AM
    TeamGoose
    TeamGoose [OP] Threat Level Midnight, Michael Scarn
    Temple, TX
    2020 Tundra TSS 4x4 Cement
    OEM LED Headlights, TRD Shifter, Interior LEDs, 6112(1.9) & 5160 reg. height
    I had the “ Factory Remote Start “ installed by the dealer when I bought the truck. In my option, IT’S GARBAGE!!
    it uses the original key fob and you press the lock button 3 times. Takes multiple times before I get it to work. Half the time when it starts the horn/panic will go off with it. I have to manually unlock the door with the key, key fob won’t do it and when I asked the dealer why that would work they said it’s a safety issue and that none of the trucks with remote start will allow a key fob to remote open a door.
    Does anyone else have this issue?? Or do I need to take this to another dealer or take it back to the dealer that installed this and tell them they are full of it and need to fix it?!
    whodini12 likes this.
  2. Feb 21, 2020 at 4:06 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Compustar remote start...$385 installed 1 mile start radius :)
    CoachJ and plumber802 like this.
  3. Feb 21, 2020 at 4:07 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Tell them to take it out, get your money back if you paid for this option and get an aftermarket
  4. Feb 21, 2020 at 4:20 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    “I have to manually unlock the door with the key, key fob won’t do it and when I asked the dealer why that would work they said it’s a safety issue....”
    That’s not accurate; the fortin unit that James (@tech12volts) sells starts my truck with three presses of the lock button, I can unlock with the fob, open the door (truck stays running - some units shut off as soon as you open the door), put key in ignition and turn it on......works like a charm. Factory start may be different but there’s a possibility that they didn’t tap into the right wire to enable it to unlock with the fob when remotely started.
  5. Feb 21, 2020 at 4:28 AM
    timsp8
    NY
    I have an aftermarket one and can unlock the doors with the key fob after I remote start. When they installed mine they had the issue of the alarm going off, but they kept adjusting the settings and got it fixed.
    It stays running after door opens too. Have to hit the brake to turn it off. Mine also doesn’t have the 10 min timer. It’ll run til it’s out of gas.
    Try to unlock first, then hit lock 3 times. Alarm shouldn’t go off then as I think there is a 60 second window after hitting unlock before alarm rearms.
  6. Feb 21, 2020 at 5:28 AM
    kodiak
    kodiak New Member
    Factory toyota remote start is garbage. Shuts off when you unlock from the fob, shuts off when you open the door, range sucks, etc.
    Minarets likes this.
  7. Feb 21, 2020 at 5:32 AM
    Kanobi13
    Kanobi13 New Member
    I have 12 volt solutions plug and play easy install I can unlock doors and will not shut off when doors is opened. It will shut off of i do not put key in before pressing brake pedal.
  8. Feb 21, 2020 at 6:23 AM
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Fortin remote start on my 18’. Uses factory key. 3 locks and it’s running. Works flawlessly. So well in fact, I just put the same one on my wife’s 18’ highlander.
  9. Feb 7, 2021 at 1:40 PM
    NashDash
    NashDash New Member
    Art
    Nashville
    2018 Tundra Platinum 4x4
    New Tundra owner here. I bought a truck with I don't know which type of remote start brand it is, OEM or aftermarket. I had no clue it had one until I accidentally started it one day with the factory key fob. 3 clicks of the lock button, it was working fine, parking lights come on, and idles put the key in the ignition, etc. Recently now it comes on only for a few seconds, and parking lights just flicker on and off when it's trying to stay running. Any thoughts and recommendations?
  10. Feb 7, 2021 at 2:45 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    Having an idea what brand it is might help. If its just three clicks of the lock button, and not 2 clicks, hold down on the 3rd for 3 seconds, it's probably aftermarket, and most likely a Fortin Evo One (a popular unit for our trucks). If I had to guess, its a tach sensor issue. I believe the Fortin gets that info thru the Can-Bus connection. Check to see if its loose, or disconnected.
  11. Feb 7, 2021 at 3:24 PM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Check under the hood and see what's hooked up?
  12. Feb 8, 2021 at 8:51 AM
    NashDash
    NashDash New Member
    Art
    Nashville
    Well it's not Fortin. It set off the alarm while it was trying to start. Don't know exactly what I'm looking for under the hood. Any help or advance would be greatly appreciated.
  13. Feb 8, 2021 at 8:55 AM
    pearlpower
    pearlpower New Member
    2014 CrewMax in Radiant Red
    I installed the Start-X, a bit under 1-hr, and so far it works perfect, without the issues listed above. I ordered the
    Carlink app start so all in I'm around $355 providing my own labor.
    https://amzn.to/3cYXveF
    https://amzn.to/2MKVmbE
  14. Feb 8, 2021 at 9:08 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    I believe, don't quote me, and it's way to cold for me to go uut aside and look around (sorry) but the installer put a sticker on the battery saying compustar remote installed. But again don't quote me.
  15. Feb 8, 2021 at 5:53 PM
    BenSan
    BenSan New Member
    Ben
    2020 TRD PRO
    Yeah, mine do the same shit and range suck balls smh
  16. Feb 8, 2021 at 6:27 PM
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    I do hate that it turns off when unlocking or opening door (makes no sense to me) but I do love the Toyota connected services. Just for shits and giggles I tried locking my doors from my hotel room in Atlanta this past week (I was in my wife’s QX80) and it started in my drive way in Nashville. Now, I obviously do t need that kind of range but knowing I can lock my doors or unlock from virtually anywhere is kinda cool to me.
    Plus I like some of the other features.
  17. Feb 9, 2021 at 7:13 AM
    19TurdPro
    2019 Tundra TRD Pro
    The unit itself would most likely be under the dash somewhere. Did you check the Can-Bus connection?
