Factory radio swap
Discussion in 'Audio & Video' started by Kotara, Dec 12, 2020.
  1. Dec 12, 2020 at 12:36 PM
    Kotara
    Kotara [OP] Organized Chaos
    Maine
    14 Tundra TRD SR5
    Rear air bag suspension
    Ok I have looked around and I haven't found exactly what I'm looking to do. Is it possible to upgrade my radio to a premium H/U with out having a premium in there currently? Or is this just a wasted idea?
    YardBird likes this.
  2. Dec 14, 2020 at 3:16 PM
    All of the OEM radios are horrible. Why not go aftermarket?
    WILLINH, 1lowlife and Saltyhero13 like this.
  3. Dec 14, 2020 at 3:43 PM
    Saltyhero13
    Saltyhero13 Throbbing Member
    +1. In this situation, for the money spent on an OEM Premium head unit and ancillary devices I would entertain a price comparison with going full aftermarket as an alternative. The only case I see keeping a Tundra headunit is if you want to keep access to the vehicle menu options. Even in this situation you can get aftermarket data devices that restore these options when using aftermarket headunits.
    @Kotara I think you'll be disappointed with the JBL head unit's output if you haven't heard it. The main issue is the JBL headunit rolls off some of the base to preserve the other speakers. The reason it does this is because the speakers that come with the JBL upgrade aren't super high quality for a "high end" OEM system. Unless you're running a partially upgraded system, you are also likely to need a replacement of some of your speakers and the amp(s) to drive them. At that point your at a full upgrade minus the radio.
    Kotara[OP] likes this.
  4. Dec 14, 2020 at 3:47 PM
    Yep, the Maestro retains the vehicle options. The only thing you lose is the factory microphone. There is a USB retention adapter available to keep the factory USB port. As another member mentioned, upgrading everything except for the head unit is like driving a Ferrari powered by a Honda motor.
    Saltyhero13[QUOTED] likes this.
  5. Dec 14, 2020 at 3:50 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  6. Dec 14, 2020 at 3:58 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Welcome from the wet side of WA. If it were me, I'd listen to these guys. Hell, dropping in a reasonable aftermarket HU with Carplay/Android Auto with the Maestro setup will only set you back ~$500 (assuming you don't swap anything else out) and you'll get a noticeable improvement without losing any vehicle menu functions. To do a JBL "upgrade" on a non-JBL truck, you're going to have to find:
    • Head unit
    • Amp
    • Subwoofer
    • Additional speakers and the panel trim for them
    • OEM connectors for hooking up to everything
    And then you're still going to have to tear the truck apart to install it all (amp under the passenger front seat, sub behind the rear seat, pulling door panels for speakers). If you're pulling all that apart anyway...well, you'll probably find some pretty nice aftermarket parts for a fraction of what you'll buy those parts off Toyota for (unless you cash in on someone else upgrading their system and tossing all their old parts out for next to nothing).
    Saltyhero13 likes this.
  7. Dec 14, 2020 at 3:59 PM
    Saltyhero13
    Awesome. Thanks for clarifying.
    We'll see how it goes as I'm doing what you described. I'm keeping the head unit and basically replacing/upgrading everything else. Worse case scenario I replace the headunit after the fact.
    RainMan_PNW likes this.
  8. Dec 14, 2020 at 4:03 PM
    RainMan_PNW
    Casey
    Clark County, WA
    I would also add - I did a 2010 JBL swap into a 2008 JBL truck (2010 added the USB port and streaming BT audio) and just doing that was a process - several months of wiring diagram research, finding/buying the right extra parts/pieces (the USB actually routes to a "multimedia controller" that sends the signals to the HU), and then doing the install (de-pinning and re-pinning all different connectors for the back of the HU). And that didn't touch any of the output parts (amp, sub, etc.). I only did it because I managed to find the HU for about $50 on ebay, and the other parts summed out to under $100 from lots of time searching wrecked trucks, AND because at the same time I did the auto-AC climate control upgrade and got rid of the piano black in favor of the charcoal parts in my truck. And, after doing that, I would never do it again for a radio that really isn't much better than the stock "non-premium" one.
  9. Dec 14, 2020 at 4:04 PM
    Saltyhero13
    Great breakdown. I didn't think of the trim for the additional speakers the other system wouldn't have.
  10. Dec 14, 2020 at 4:07 PM
    RainMan_PNW
    Casey
    Clark County, WA
    Yeah, and when a factory vent port runs $70 (discounted...MSRP is higher), god only knows what they'll want for a factory JBL tweeter and the door trim for it.
  11. Dec 14, 2020 at 4:07 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    4/2 Ready lift Kenda Klever 35 x 12.50 x 20 XF Off road wheels
    I just finished upgrading my non JBL stereo system in my 2020 Tundra. I kept the stock head unit and I'm glad I did. The stereo system now is night and day compared to how the truck came from the factory. I don't know why people say to get rid of the stock head unit. It works perfectly fine with my setup and all my functions still work.
  12. Dec 14, 2020 at 4:11 PM
    ezdog
    ezdog New Member
    Gateway To The West
    So I bought a better non jbl factory radio for mine and it was a pretty solid upgrade honestly and about $150 if I remember correctly too.
    You cant get anything aftermarket in there near that price I bet and I listen to music at home and it was a great upgrade for me.
    I admit I was surprised by how much better it all sounded with the better factory radio.
    And I sell Audio for a living.
  13. Dec 14, 2020 at 4:13 PM
    RainMan_PNW
    Casey
    Clark County, WA
    What upgrade(s) did you do specifically?
  14. Dec 14, 2020 at 4:13 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    ^ I'd have to agree with this statement..
  15. Dec 14, 2020 at 4:23 PM
    Saltyhero13
    I don't see anything wrong with this. This is basically what I'm doing with my JBL head unit. I'm keeping the head and gutting the body.
    However, I would note that the OPs situation is different. He has a nonJBL unit and wants to replace it with a JBL unit. Its not a simple swap of the head unit as he would also be missing some of the speakers that come with the premium audio.
  16. Dec 14, 2020 at 4:25 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
  17. Dec 30, 2020 at 3:34 PM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
  18. Dec 30, 2020 at 4:49 PM
    JcGc
    JcGc New Member
    2020 Crewmax 4x4
    Kicker Model #44KXA8005
    I bought it from Best Buy
  19. Jan 5, 2021 at 4:42 PM
    Yotaholic
    Yotaholic Amateur Professional
    Lone Star Republic
    2011 TRD DC 4.6
    I just found a wrecked 2012 Tundra with JBL stereo. I'm a little confused....is this a plug & play install into my non-JBL TRD package 2011 Tundra?
  20. Feb 24, 2021 at 8:08 AM
    RainMan_PNW
    Casey
    Clark County, WA
    It is not. The JBL stereo also has the subwoofer, the amp, and the additional speakers that are part of the package (and all of the wiring to them) that would also need to be installed.
  21. Feb 25, 2021 at 9:17 PM
    Yotaholic
    Lone Star Republic
    2011 TRD DC 4.6
    Thanks for the reply, I was meaning to ask if I could install all the speakers and just plug them in to any existing wiring in my truck. It seems that isn’t possible and the junkyard wanted WAY too much money for the system anyway. I said forget it
    RainMan_PNW[QUOTED] likes this.
  22. Feb 25, 2021 at 9:22 PM
    RainMan_PNW
    Casey
    Clark County, WA
    My 2008 SR5 came with the JBL audio, which meant it actually had all the wiring for a Limited and just didn’t have all the parts installed. In 2010, they stopped doing that - in part because the lower trim trucks actually got some of the features like Bluetooth and steering wheel controls that were not available in the 2007-2009 without the JBL head unit. So, yeah, adding the wiring for the extra speakers and buying the additional parts, you’d be money ahead with a decent aftermarket head unit and upgrading the factory speakers.
    PickupMan2008 likes this.
  23. Mar 3, 2021 at 9:16 AM
    Dowdib
    Dowdib New Member
    2012 crewmax platinum. I want to replace my OEM head unit jbl with an aftermarket pioneer unit. What harness/interface is required to keep steering wheel controls, camera etc?
  24. Mar 3, 2021 at 9:18 AM
    Check with Crutchfield. I cant remember if there is a Maestro unit for the 2nd gens.
  25. Mar 11, 2023 at 5:51 PM
    rmeyer7
    rmeyer7 New Member
    Roy
    2008 Double Cab 5.7L
    Guess I'll resurrect this old thread rather than start a new one...
    Just bought a 2008 base model, so the head unit in this pic is the one that's in it.
    My question is, what's the least laborious option anyone has gone with to upgrade one of these to something with Bluetooth and the ability to connect a backup camera to it? I don't care much about Android Auto and Car Play, though I'm sure any decent unit will have them.
    Anyone have experience with Stinger units? I like the look of theirs (below). Curious if anyone has installed one in a Gen 2 and how it fits, looks and most importantly works.signal-2023-03-11-194915_002.jpg
