Factory radio interchange
Discussion in 'Audio & Video' started by Cruiserpilot, Dec 9, 2020.
  1. Dec 9, 2020 at 7:07 AM
    Cruiserpilot
    Cruiserpilot [OP] New Member
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I have a 2007 Tundra SR5, pretty basic. For some reason the PO replaced the factory unit with a JVC. I found a complete radio AM FM CD out of a 2007 4Runner including amplifier. No wiring, but would this plug into factory wiring on my Tundra?
  2. Dec 9, 2020 at 8:10 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Yes. lol... Its probably the same plug across all brands as well... Odds of ditching the stock radio are various, but probably lost some CDs in there and it refused to let them go, like mine, only way to get them back is busting it open.....
    Sean492 likes this.
  3. Dec 9, 2020 at 8:26 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Ok, it is $50 on FB. Someone sent it to me. I’m afraid to look behind the JVC cause if they hacked the factory wiring I’m buggered.
  4. Dec 9, 2020 at 9:14 AM
    blackdemon_tt
    ummmm... damn it Jim, odds are it is.... I got a head unit installed on my Celica at a shop and when that radio failed I went to replace it with the stock one and the pigtail was gone. So I went to Oreilly since it was a couple blocks away and looked for an adapter and noticed it was the same pigtail for the radio since 1989. So I swung by the salvage yard and picked one out of a Corolla as they were interchangeable, I removed the pigtail and replaced it with the Corolla one and made an adapter with the Oreilly pigtail for the new head unit... You may need some solder, or an effective method to keep wires in contact if you don't..
    Sean492 likes this.
  5. Dec 9, 2020 at 9:32 AM
    You need to pull the JVC and look at it. Get a pic of the radio for sale and post it so we can see the connectors. Having Tundras and 4Runners, they are not all the same.
  6. Dec 9, 2020 at 9:35 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    Here it is BTW, I’m totally new to Tundra world. 3 Land Cruisers all from the last century. So I’m progressing slowly.
  7. Dec 9, 2020 at 9:46 AM
    blackdemon_tt
    2 of those plugs on the right look identical to my 2002 Celica, the big one and the small middle one. The plug on the far left hand side looks similar to the jbl option radios, which mine doesn't have. if you look for adapters for your radio, that will give you a good idea that it would plug right in.
    Cruiserpilot[OP] likes this.
  8. Dec 9, 2020 at 11:13 AM
    jalam321
    jalam321 New Member
    2018 Tundra CM Platinum 4x4 and Sequoia Platinum 4x4
    It won't be direct fit but you can probably get it to work. The plugs should fit but radio might not fit in the dash correctly. I think you are better off getting an original Tundra radio if you want to go back to OEM.
  9. Dec 9, 2020 at 1:28 PM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I think this is the way I’ll look. It just showed up. Thanks for the advice
    jalam321[QUOTED] likes this.
  10. Dec 9, 2020 at 2:55 PM
    Thinking about it...the dash and contours are different between the 4R and the Tundra. The tundra is more rounded.
  11. Dec 10, 2020 at 7:02 AM
    blackdemon_tt
    The radio plugs are interchangeable, but its a completely different radio than the 07.
  12. Dec 10, 2020 at 7:17 AM
    Cruiserpilot
    Jon
    Ladysmith
    2010 5.7 RCSB 4WD
    I was looking around. I won’t do this 4 Runner radio. There is a good D DIN radio here on want ads for reasonable. I’ll wait until I get the timing belt/tune up in January done.
