Factory Mic w/Aftermarket Head unit?
Discussion in 'Audio & Video' started by RussellVaughan, Sep 4, 2019.
  1. Sep 4, 2019 at 8:36 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    According to Crutchfield, there is no way to use the factory (built-in) microphone with an after market head unit. Is this true? How come?
  2. Sep 4, 2019 at 8:40 AM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    Doesnt work in a 2019 4Runner, I know that much.
    It is pretty freaking stupid
  3. Sep 7, 2019 at 9:07 AM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
    I did some research on this recently because I was installing my Kenwood DNX996XR. From what I have read and put together from a few places, the factory microphone connection has wires that goes from the radio up to the headliner, and connect in to a small powered amplifier that is connected to the microphone. So the factory mic is a powered/amplified microphone and after market head units need a non-powered microphone signal. So to use the factory mic, you need to remove the factory mic from the headliner/ceiling and cut the wires off of the mic & amp, and then solder on two new wires to bypass the amp and go directly from the factory wires to the mic connection. Once that is done, then you can tap into the factory wires at the radio and wire those up to the aftermarket head unit. (But I don't know yet which wires those are).
    Eventually I might try this, but for now I used the mic that came with the kenwood radio.
    For reference, this is where I got most of the info:
    https://www.tundratalk.net/forums/t...605-adding-aftermarket-stereo.html#post980855
  4. Sep 7, 2019 at 9:26 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    No the stock mic has a built-in amp and won’t work, it’s been tried on another Tundra forum. I did solder an aftermarket mic and tunneled the wire, behind the pillar, to the visor.
    Kerch71 likes this.
  5. Sep 18, 2019 at 8:52 AM
    RussellVaughan
    Houston
    Thanks for the info yal! Sucks it's not possible, but at least I understand why now.
  6. Sep 18, 2019 at 8:54 AM
    NateDiz
    NateDiz Sunday Tunday
    Nathan
    So Cal
    2013 MGM CrewMax TRD
    Trd Pro Suspension, spyder headlights with morimoto HID, Raceline Defender Wheels, AFE filter, Dirty Deeds 8” exhaust
    I pulled the factory mic out and put the aftermarket mic in its place. Turned out great
  7. Oct 23, 2019 at 2:04 PM
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    Got any pics? I don't even know where the factory mic is
  8. Oct 23, 2019 at 2:23 PM
    TXTundra2722
    2015 Black Tundra
    Which mic did you go with?
  9. Oct 23, 2019 at 2:28 PM
    NateDiz
    Nathan
    So Cal
  10. Oct 23, 2019 at 3:37 PM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    A cheap but well-reviewed Kenwood replacement mic off Amazon Canada.
  11. Oct 24, 2019 at 11:29 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    unplug/remove factory mic, install the aftermarket mic in the factory location. position is not ideal, but at least its not sticking out like eyesore. (DDX9904S)
  12. Dec 23, 2020 at 6:39 AM
    donellyd
    donellyd Member
    Eastern PA
    2020 Sequoia TRD Pro
    SOLD: 2008 Sequoia Limited SOLD: 2004 Sequoia Limited
    Looks like some folks got the factory mike to work by by-passing the mike amp. Check it out @ Tundra Solutions...
  13. Dec 23, 2020 at 5:11 PM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    I had the same dilemma when I gutted the JBL system out of my Platinum. In the end, I used the Kenwood supplied mic and installed it in my instrument cluster trim ring by drilling a hole and using a rubber grommet. Looks factory and voice reception is fantastic. Just an option that is quite easy to do:
    bulldog93 and pickeledpigsfeet like this.
  14. Jan 1, 2021 at 7:26 PM
    Astropuppy
    Astropuppy New Member
    2011 Tundra SR5
    That looks sharp. Doesn't that trim have to come off to get the old hu out?
  15. Jan 1, 2021 at 7:34 PM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That particular trim does not...that's the trim around the speedometer.
  16. Jan 1, 2021 at 7:36 PM
    Astropuppy
    2011 Tundra SR5
    Was it hard to pop off? On a Corolla I flexed it and ran the wire through the gap then used double sided tape. your install is much cleaner.
  17. Jan 1, 2021 at 7:46 PM
    RainMan_PNW
    Casey
    Clark County, WA
    To just pull it loose, there are two push-pin style clips in the top of the "hood" of that trim. You push in the center of the pin with a #1 phillips screw driver, and then the clip will drop out, and then you can pop that trim loose (but not remove it fully). To fully remove it, you need to also free up some clips along the top of the steering column that hold in a vinyl "skirt" between that trim and the steering column. BUT FIRST there are other trim pieces that need to come out as well...
    If you go to the Hypertech website and download their instructions for the speedometer calibrator for the Tundra, it actually gives a great walk through on how to pull that time (because you need to get to it to install their calibrator).
    bulldog93 likes this.
  18. Jan 1, 2021 at 7:52 PM
    Astropuppy
    2011 Tundra SR5
    Thank you soo much. Pictures make it easy.
  19. Jul 25, 2021 at 1:36 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I'm using the factory Mic, however, it does taking some rigging. I bought a universal microphone with a 3.5MM male Jack and ran the cable to the factory mic. Clipped off the microphone head off the universal cable off exposing the bare wires inside. Pulled the factory mic apart, unsoldered the microphone off the factory microphone amp and soldered the two wires to the universal microphone cable bare wires.
    silverhack likes this.
  20. Oct 13, 2021 at 4:04 PM
    FreeballBob
    FreeballBob New Member
    Bob
    2019 Tundra 5.7 Crewmax 4x4
    Toyo-tech 3 inch lift, wheels and tires
    I did this Hardwire mod to my 2014 Tacoma. Cut out and off the factory amp for mic and wired alpine mic wires to factory mic. Worked flawlessly, about to do to my 2019 tundra, I’ll let you know how it goes and drop a photo or two.
    Do58 likes this.
  21. Nov 3, 2021 at 7:13 PM
    Tundra John
    Tundra John New Member
    2020 Tundra Platinum 4x4
    4” Readylift, Fuel 20” tires w/ Kenda 35”x12.5 tires, tint, dechromed, Custom Platinum Badging, Running Boards, Auto tailgate lock, LED swap, Changed out stereo system, VLeds Interior floor lights, DirtyDeeds 8” exhaust, TRD air filter, wrapped interior silver components,
    Did this work out for you? I have a 2020 and hoping to keep the factory mic.
    FreeballBob[QUOTED] likes this.
  22. Nov 3, 2021 at 7:48 PM
    Do58
    Do58 New Member
    This would be amazing
  23. Nov 3, 2021 at 8:47 PM
    Devius1
    Devius1 5150 Member
    NorCal
    MGM 2019 Platinum
    Here's an idea...
    https://youtu.be/_GO2Zyr7Ecg
    2x taped my mike to the upper corner of the windshield for the meantime.
    Been there for 2yrs. :rofl:
  24. Nov 3, 2021 at 9:10 PM
    FreeballBob
    Bob
    Funny story, guy sent my new head unit without the mic and mic plug (alpine) I hooked it up anyway using an IdataLink Maestro and it incorporates the factory mic, or so I believe because it works and I connected nothing but the Maestro and Toyota specific harness. Not going to waste my time at this point to see if the tundra mic is the same as the Tacoma but I’m sure it is.
  25. Nov 4, 2021 at 3:27 AM
    Tundra John
    So the iDatalink Maestro incorporated the factory mic?? That’s great, especially since I have the Maestro coming with my radio. Hopefully it works with a Pioneer. I guess I will try to hook it up without the mic and see what happens.
    FreeballBob likes this.
  26. Nov 4, 2021 at 4:31 AM
    How did you do this? I have a 2020 with Pioneer and Maestro and the sheets do not show that the factory microphone as being retained. I am not aware of any cable that retains it either. I have the retention cable for the factory USB, so the mic is the only thing that I lost.
  27. Nov 4, 2021 at 4:33 AM
    I just posted on this. I have a Pioneer with Meastro RR and I am not aware of keeping the factory mic. The data sheets even say that it is not retained. Did you order the USB retention cable too?
  28. Nov 4, 2021 at 5:06 AM
    Tundra John
    Yep, I did order the USB retention cable. I even got the PacVS41 camera switcher. It should display the view from a side camera when you turn a blinker on.
    I get everything tomorrow and hoping I have tine this weekend to install everything.
  29. Nov 4, 2021 at 5:11 AM
    You have side cameras? Interested in that mod....
  30. Nov 4, 2021 at 7:31 AM
    Tundra John
    I dont have them yet but thought it would be a good mod.
