F/S-FOX 2.5 DOUBLE BYPASS W/HARD MOUNT RESI'S
Discussion in 'Marketplace - Other' started by bandit, Jan 9, 2017.
Thread Status:
Not open for further replies.
  1. Jan 9, 2017 at 11:15 PM
    bandit
    bandit [OP] New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    They work on the front for you long travel guys too :)
  2. Jan 10, 2017 at 5:56 AM
    Weren't those the ones going on the 4R?
    bandit[OP] likes this.
  3. Jan 10, 2017 at 9:03 AM
    TheBeast The Beach
    changes of plans..keep up with the program ;)
    bandit[OP] and T-Rex266[QUOTED] like this.
  4. Jan 10, 2017 at 12:51 PM
    bandit
    Duh Tundra
    Yes but now we're doing 48" trailing arms in the rear so I need significantly longer shocks.
    2cID likes this.
  5. Jan 10, 2017 at 12:51 PM
    bandit
    Duh Tundra
    Lmao
    2cID and 650h1 like this.
  6. Jan 10, 2017 at 7:26 PM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Bandit, I haven't looked at you previous Tundra build but on these; we're you using K37 spring over style or spring under I96 / custom setup? I might consider these depending
  7. Jan 10, 2017 at 11:11 PM
    bandit
    Duh Tundra
    These were used on the front long travel kit of my tundra. They will only work on the rear as a factory replacement setup. Unless you have a long travel front kit you want to put these on. If you were to run SUA you will need longer shocks.
  8. Jan 11, 2017 at 6:46 AM
    Hattori
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    Got cha, mine is a Mid Travel setup so possibly run em on my rear with the k37's spring over as they're about a inch over my current FP Resi units. I could use the extra length in the rear since its 1.75 shackles and the 1.5 deaver size springs.
    drop me a PM bro!
    bandit[QUOTED][OP] likes this.
  9. Jan 11, 2017 at 12:45 PM
    bandit
    Duh Tundra
    oh in that case yes, they would work really well. I thought you were SUA. You drop me a PM! lol
Thread Status:
