Extreme inner tire wear
Discussion in 'Wheels & Tires' started by Krautman73, Feb 11, 2020.
  1. Feb 11, 2020 at 7:44 AM
    Krautman73
    Krautman73 [OP] New Member
    Austin, Tx
    2018 SR5 Crewmax TSS
    6" Maxtrac suspension lift 20x10 KMC XD Buck 25s with -24 offset 35x12.5x20 BFG KO2s Cherry Bomb Extreme muffler 2/1 Stubby antenna
    Hey folks, had my truck at Discount Tire a few days ago for a rotation and balance and was alerted to some extreme uneven tire wear (only 10,000 miles on tires). The front tire's inner tread was worn down enough to warrant replacing the tires. Eight hundred and some dollars later, I replaced the tires, and am currently at the alignment shop. With my - 24 offset rims, the tech isn't sure his equipment can provide an accurate reading. So, while I'm waiting, I thought I'd check if anyone else with a similar setup has experienced this issue. I realise that ball joints, tie rods and shocks could potentially be the culprit, but being a 2018, I'm leaning more towards the alignment being out of whack. As a side note, after my lift was installed, the alignment was done with the stock rims and tires, so don't know if that could be part of the problem.
    6" mactrac suspension lift
    stock ucas
    20x10 rims w BFG KO2s
  2. Feb 11, 2020 at 7:45 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Got any pics?
  3. Feb 11, 2020 at 8:20 AM
    Krautman73
    Austin, Tx
    Turns out the alignment shop was able to do some magic, and complete the alignment. The tech said that the folks that performed the initial alignment had no idea what they were doing, as the alignment was completely out of whack!
    The Californian likes this.
  4. Feb 11, 2020 at 9:27 AM
    Did they give you a before and after printout?
  5. Feb 12, 2020 at 12:03 PM
    Krautman73
    Austin, Tx
    No, I was just Stoked that they were able to resolve the issue and hightailed it out of there
  6. Feb 12, 2020 at 12:20 PM
    15whtrd
    15whtrd Mr. Blonde
    Just confirm that the LCA bolts are tightened enough. They should be 207 foot pounds.
