External Transmission Cooler Plumbing
Discussion in '3rd Gen Tundras (2022+)' started by Dozer466, Apr 17, 2024.
  1. Apr 17, 2024 at 9:29 AM
    Dozer466
    Dozer466 [OP] New Member
    2022 Tundra TRD Pro
    Westcott 3/1, 37" Toyo's, Smartcap
    For those that have installed an external trans cooler, where are you plumbing into on the transmission side? Thanks in advance.
  2. Apr 17, 2024 at 9:31 AM
    mass-hole
    mass-hole New Member
    I would plumb it in series after the existing liquid cooler and use a thermostatically controlled Hayden cooler. That way if the trans fluid is being pumped through to help it warm up, you are not also cooling it down with your external cooler.
  3. Apr 17, 2024 at 11:15 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
