Anyone Help me Find a 3.91 2006 Limited Slip Rear Differential?
Discussion in '1st Gen Tundras (2000-2006)' started by bmwahba, Jan 5, 2022.
  1. Jan 5, 2022 at 8:28 AM
    bmwahba
    bmwahba [OP] New Member
    I am searching for a tundra limited slip differential 3.91 ratio for my doublecab. Mine is making howling whining noise and I've searched the entire country on car-part.com to find one and haven't come across one.
    Anyone have a spare or know of anyone with a part out? It must be whine-free and wear-free beyond normal wear and tear. Just can't cough up the $1300 from ECGS currently.
  2. Jan 5, 2022 at 8:41 AM
    You have a 2006 double cab and the rear end is 3.91? Believe all of those are 4.10's. If you are 2wd, then it could work. Need more info to help.
  3. Jan 5, 2022 at 8:43 AM
    bmwahba
    No im pretty sure it’s a 3.91 LSD. At least that’s what the dealer told me and the vin decoder.
  4. Jan 5, 2022 at 8:44 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    I think it's just the 2004 DCs and some Sequoias that came with the 4.10's.
    OP should be able to confirm here though if not 100% sure. https://www.toyota.com/owners/my-vehicle/vehicle-specification.
    Good luck OP! Hope you can figure it out.
  5. Jan 5, 2022 at 8:45 AM
    Is your truck the access cab configuration with the 2 clamshell doors, or the "crew cab" configuration with the 4 full size regular opening doors?
  6. Jan 5, 2022 at 8:45 AM
    bmwahba
    4 door double cab.
  7. Jan 5, 2022 at 8:58 AM
    Does appear to be either the 3.91 or the 3.92 depending on drive type. Not sure what the subtle difference is, but would make sure it came out of the same type as yours, whatever that is.
  8. Jan 5, 2022 at 9:29 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    There's a page of 3.91 locking that show up when I search? Although the cheapest is still $1100.
    Couple things though. It doesn't NEED to be an LSD rear, you can replace it with a non. If you're truck is only 2wd it doesn't NEED to be 3.91 either, you can swap whatever you'd like in there.
    It may be cheaper than both options to have a local shop diagnose and maybe just need get a rebuild
  9. Jan 5, 2022 at 9:31 AM
    bmwahba
    Yeah my local shop wants $1200 for a full rebuild with an LSD. And my truck is 4x4 so needs to be 3.91.
    I’m just hoping to find a decent used one to hold me over for a while. The truck runs fine actually but I need to get rid of the whining that’s driving me nuts
  10. Jan 5, 2022 at 9:34 AM
    Schcoman
    Schcoman From behind the Redwood Curtain
    Humboldt Co. CA
    2000 Access Cab 4.7L V8 4x4 SR5
    None
    Best of luck to you. I needed a 3.91 open diff and the best I could find was $1400 at a dealership in Georgia. I live in California, so shipping cost way too high. Pretty much not an off the shelf part. OEM on order, $2150. and it's taking forever to get here. Argh! At least I get a full warranty.
  11. Jan 5, 2022 at 9:56 AM
    bobjones
    bobjones New Member
    03 tundra on 37s
    What state are you in? you can find a LSD 3.91 ratio all day at any Toyota wrecker. ebay has one with free shipping for $526. ECGS will rebuild it for $750 if you want to go that route
  12. Jan 5, 2022 at 10:34 AM
    Schcoman
    Humboldt Co. CA
    None
    I need the whole carrier and do NOT want used. Appreciate it. I don't have the shop or tools or time to mess with a rebuild. Thanks
  13. Jan 5, 2022 at 10:48 AM
    bobjones
    bobjones New Member
    03 tundra on 37s
    I was responding to Bmwahba as he's looking for a used 3rd member. Schcoman are you a having a shop do the removal and install?
    Schcoman likes this.
  14. Jan 5, 2022 at 10:58 AM
    Schcoman
    Humboldt Co. CA
    None
    Yes. Thanks. Misunderstood your reply. My Bad.
  15. Jan 5, 2022 at 12:42 PM
    bmwahba
    Hey Thanks. I am in Florida but I will cover shipping. Where is the link to that one on ebay? I don't see it. Can you source me one? I am open to non-LSD just for sake of finding one, but would of course prefer to keep my LSD if I can find one.
  16. Jan 5, 2022 at 1:01 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
  17. Jan 5, 2022 at 1:28 PM
    bmwahba
  18. Jan 5, 2022 at 1:32 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
    2000-2006 tundras and 2001 to 2007 sequoia all used 30spline axles with the "8.4" bridge cap third member. This makes it pertty cool because you can get factory thirds with 3.90, 4.10 and 4.30 ratio gears
  19. Jan 5, 2022 at 1:44 PM
    bmwahba
    From the research I've done, only a doublecab rear carrier will fit in my truck. Am I wrong? And does it need to be specifically an 05-06?
  20. Jan 5, 2022 at 1:50 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
    As far as i've found they all are interchangeable. Where did you find the info saying they are different?
  21. Jan 5, 2022 at 1:52 PM
    des2mtn
    SW
    Tonto cover
    I think that the difference is the width of the entire axle housing. The double cabs may be different from the ACs and RCs. In that case, it's the axle shafts that are different and not the third member that would be different.
    @empty_lord or @assassin10000 may be able to confirm
  22. Jan 5, 2022 at 1:53 PM
    bmwahba
    Gotcha. Well that makes sense. Either way I don’t want to swap my whole axle I would much rather just swap the pumpkin. Fingers crossed I can find a 3.91 LSD….
  23. Jan 5, 2022 at 1:58 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
    Your biggest problem with a used LSD 3rd member will without a doubt, not be limited slip any more. Mine was worn out and from what ive found they wear out in about 50,000 miles more or less. So you'd be getting an "open" with a used unit
    txagg likes this.
  24. Jan 5, 2022 at 1:59 PM
    bmwahba
    Definitely likely, but oddly enough my buddy has a 380k mile tundra with LSD And it works perfectly..
  25. Jan 5, 2022 at 2:06 PM
    des2mtn
    SW
    Tonto cover
    Just took a quick look at the specifications for 2004.
    RC rear track width: 64.9"
    AC rear track width: 64.9"
    DC rear track width: 67.3"
  26. Jan 5, 2022 at 2:07 PM
    bmwahba
    Right so that affects only the axle one would presume and not the carrier itself. And anyway either way I’d need a double cab limited 05 06 if I want the LSD and the 3.91
    des2mtn likes this.
  27. Jan 5, 2022 at 2:20 PM
    bobjones
    bobjones New Member
    03 tundra on 37s
    yeah that doesnt affect the 3rd member at all. My 03 came with a LSD and 3.91 GR so you can use any year you like that has that ratio
    des2mtn likes this.
  28. Jan 5, 2022 at 4:19 PM
    bmwahba
    Was there any LSD that was not a 3.91? Or were all the LSDs 3.91 ratio? I just found one for pretty cheap, it is an LSD, but they don’t know what gear ratio.
  29. Jan 5, 2022 at 4:54 PM
    bmwahba
    I just need to confirm that it will work. It is 100% an LSD, and all my google-fu skills are showing that only a 3.91 lsd pops up. So is it safe to assume it’s a 3.91 if Toyota never offered any other gear ratio for the LSD?
  30. Jan 5, 2022 at 4:56 PM
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    Do they know they VIN of the donor truck? You can look that up to see what it is.
    car-part.com produces a list of dozens of candidates, but you'll have to get on the phone to ferret out the one you want:
    www.car-part.com
