Extended wheel studs? Spacers installed.
Discussion in 'Wheels & Tires' started by Erick, Aug 29, 2020.
  1. Aug 29, 2020 at 7:04 PM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    I'd really like 10 extended wheel studs.
    I installed some front and rear spacers. Using stock wheels.
    I noticed in the notes that the manufacturer says that I may need to cut my factory studs down. Then another side not says make sure that I get at least 6 fill spins on the inner nuts / studs. I got over the 6 full spins.
    The rears look perfectly flush to the end of the inner lugs and studs. The fronts have about 1/4"+ on thread remaining on the inner nuts. (The factory studs look like they may need to be longer on the front. )
    I think that I should probably replace my factory wheel studs on my fronts.
    Would anyone be willing to help me out on what size I should look for? They should probably be about 1/4 - 1/2" longer than the factory front wheel studs. Any help would be greatly appreciated.
  2. Aug 30, 2020 at 9:40 AM
    triharder
    triharder Sorry, Not Sorry
    Jake
    Southern, Maine
    2010 RWB Black
    Billstein 6112/5160's, coachbuilder spacer on driver side/ 20" rockstar wheels/ 33" nitto ridge grappers/SS Brake lines (or as most people write Break), Painted Calipers/Powercoated Tow hooks/pocket flairs/heated seats,bed leds/line-x liner/xtang trifold/tow mirrors/Stereo Work/Compustar Remote Starter/ retrofit Morimoto Minin H1 and switch back LEDs/ plenty I'm forgetting
    Thread diameter. you want the number of threads engaged to match the diameter of the bolt(stud) you are attaching this too.
    (so if you are installing a 5/8-11unc nut to a stud you want at least 5 9threads engaged)
    google search
    Minimum number
    It is commonly known that the minimum recommended thread engagement to make a strong connection for a component with a tapped hole is approximately 1 times the nominal diameter in steel and 2 times the nominal diameter in aluminum. In many cases, (tapped hole in a softer material, special alloys, etc.)Mar 19, 2015
