Extended crank. Not enough fuel pressure???
Discussion in '2.5 Gen Tundras (2014-2021)' started by CiscoMn, Jan 5, 2019.
  1. Jan 5, 2019 at 8:26 AM
    CiscoMn
    CiscoMn [OP] New Member
    Francisco
    2014 red sr5 tundra
    Completely stock, not for long.
    Hey guys I have a question, not sure if anyone else has experienced this issue. I have a 2014 5.7 tundra. Just in the past few weeks I started noticing a longer crank after the truck sits over night or for a few hours. At first I thought winter temp is dropping no biggie.(located in northenn mudwest). One morning it started hard truck was shaking, misfiring, cel light came on. Checked code misfire on cylinder 1. The truck does have 99k, I figured it's due for pluds. Replaced them this past Thursday. Old plugs didn't look horrible, no carbon tracking. Just Thursday morning it took forever to start I've noticed a very long extended crank up to 5 seconds or more. Until the truck fires up. Had another shake misfire symptoms again had to hit the gas pedal to kick it out of it. Replaced the battery Thursday morning checked it said required charging, later that morning started it up again same lag. Checked alternator charging 13.99-14.0volts. any ideas what it might be? Fuel regulator? Any way of checking pressure ? Any help would be great. At the point where I might just get rid of it.
  2. Jan 5, 2019 at 8:32 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Quick and easy turn the key to "on" twice for about 5 seconds each time, then try starting it.
    Those two turns should prime the fuel system and let you know if that's the problem.
    If that helps then the check valve has probably gone bad. Good news is it's not anything serious just annoying. I had to do the same with my old Jeep and drove it that way for 2 years daily.
  3. Jan 5, 2019 at 9:24 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Don’t give be up on the truck. I agree with @Festerw. It sounds like a holding pressure issue. Not sure if Toyota has a holding pressure spec for the Tundra. If you have access to a fuel pressure gauge, start the vehicle and let it run until you have fuel pressure. Shut the vehicle off and observe the gauge (pressure vs time). Does the pressure rapidly fall off? If it does, and the vehicle sits for several hours you may experience a long crank.
  4. Jan 5, 2019 at 12:20 PM
    CiscoMn
    Francisco
    2014 red sr5 tundra
    A tech I work with actually heard it yesterday afternoon, he did advice me to cycle the key a few times. I did that this morning and it seemed to start easier. Any ideas on where I can hook up the pressure gauge. I can't seem to find any access.
  5. Jan 5, 2019 at 12:29 PM
    Porschetech29
    Francis
    LS3 likes this.
  6. Jan 5, 2019 at 12:31 PM
    CiscoMn
    Francisco
    2014 red sr5 tundra
    Awesome thanks, @Porschetech29. will give it a try when I get a chance.
  7. Feb 24, 2019 at 7:49 AM
    CiscoMn
    Francisco
    2014 red sr5 tundra
    Hey guys finally took the truck in on Friday to have the tsb done, I was skeptical about doing it and not have any change, had it done was charged more than what I was originally told but whatever. Gave her the first start of the morning yesterday and she fired like a bat out of hell. I was so relieved it did work.
  8. Feb 17, 2020 at 6:52 PM
    138thBatista
    138thBatista New Member
    Tulsa
    2010 Seq. Limited
    Sorry for the thread resurrection, but what TSB was done? Mine is doing the same thing, if it sits overnight or for a few days, it will usually crank for a while before starting, but after I've driven it any length of time, it starts right up no problem until it sits for a while again.
  9. Apr 16, 2021 at 11:09 AM
    Colorado Calvary
    Colorado Calvary Cavalry blue Tundra
    CO
    2019 TRD Sport
    @CiscoMn what TSB?
    Thanks
  10. Apr 16, 2021 at 11:14 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Flex fuels had a TSB for fuel pump and ECM reflash requirement for e85 alcohol content, something along the lines...
  11. Apr 16, 2021 at 11:21 AM
    French Avocado
    French Avocado Double Entundra
    Utah / Wyo
    Waterman1491 likes this.
  12. Apr 16, 2021 at 11:42 AM
    Colorado Calvary
    CO
    2019 TRD Sport
  13. Apr 16, 2023 at 4:49 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  14. Apr 16, 2023 at 4:51 PM
    1UP
    1UP Truck Gang
