Extended Crank 2015 FFV 5.7 Tundra!
Discussion in 'General Tundra Discussion' started by leboreiro, Apr 11, 2021.
  1. Apr 11, 2021 at 8:38 AM
    leboreiro
    leboreiro [OP] New Member
    Reyam
    Tundra 2015 5.7L
    HpTuned K&N 10.5" Cold Air Intake Custom 3" Dual Exhaust 4-1 Long Tube Headers Walbro GSS351 Fuel Pump TRD Front and Rear Sway Bars Fox Factory Race DSC 2.5" Suspension ZoneOffRoad Upper Control Arms TRD Sport Leaf Springs Fuel Stroke D642 22x12 Wheels Nitto Ridge Grapplers 35x12.5R22 Tires 4x 75ah Lithium Batteries with a front battery delete
    Hi guys. Im having extended crank every time i leave the truck off for more than 2 or 3 hours.
    Things i've replaced:
    Fuel Pump (Replaced by a walbro355lph pump)
    Fuel Filters
    Air Filter
    Cleaned Throttle Body
    Replaced Spark Plugs
    Added some Octane Booster to the Gas.
    Replaced Fuel Rail Pressure regulator a year ago.
    Did a test by installing an external Relay to my upgraded fuel pump so it will activate with they in ON position without cranking engine. I let the pump ON and flowing for about 2 minutes before trying to start the engine and STILL same issue. So im really starting to think this is not a fuel pressure issue.
    I have no CELs whatsoever, not even vaccum leak cels.
    Mods:
    I have a throttle body spacer, cold air intake, long tube headers, dual 3" exhaust, walbro gss351g3 fuel pump and hptuners tune.
    Im not from the US and my Tundra is an export. So no toyota dealerships available to update my ecu software.
    However i have the Hptuners dongle. Can fix it somehow using the hptuners?
    Or do any of you can come up with some ideas about this issue that by worth the shot to try?
  2. Apr 11, 2021 at 9:53 AM
    Occidentalis
    Occidentalis Out Snakin'
    North Florida
    2015 Inferno TRD Pro
  3. Apr 11, 2021 at 9:14 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Battery?
    Brownsfanhere likes this.
  4. Apr 11, 2021 at 9:43 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I'd side with TSB. Needs a reflash.
  5. May 6, 2021 at 4:43 PM
    Jpm64089
    Jpm64089 New Member
    My 13 5.7 flex had the cranks with no start
    It was tab 0166-19
    A refresh and $1000 fuel pump fixed it!
