Extended brake lines
Discussion in 'Suspension' started by Limited 23SC, Apr 23, 2025.
  1. Apr 23, 2025 at 7:13 AM
    Limited 23SC
    Limited 23SC [OP] New Member
    2023 Limited
    Going to put a 3"lift , Dobinson IMS on my 2023 Limited Tundra. Any front extended brake lines you recommend, or to stay away from .
  2. Apr 23, 2025 at 7:14 AM
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    You don't need to change out front brake lines on these IFS trucks. In the rear you'll need some if you're going with the longer travel rear shocks.
  3. Apr 23, 2025 at 8:32 AM
    TRD L Power
    TRD L Power New Member
    2023 SR5 XP TRD Off-Road Army Green
    Wescott Designs sells a relocation bracket that should work if you don’t want to replace the line.
  4. Apr 23, 2025 at 8:51 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    However if you want better brake pedal feel get some braided lines but its not necessary.
  5. Apr 23, 2025 at 2:31 PM
    Limited 23SC
    2023 Limited
    Thanks for the info, i can save a few bucks! I bought the Dobinsons IMS suspension from crikeymike.
    crikeymike likes this.
