Extendable tow mirrors
Discussion in 'Towing & Hauling' started by New2TundraTRD, Mar 15, 2020.
  1. Mar 15, 2020 at 2:08 PM
    New2TundraTRD
    New2TundraTRD [OP] New Member
    Adrian
    Ontario
    2011 SR5 CrewMax TRD
    Offset rims with lift in the rear w/275-65-18 10s
    I have the extendable tow mirrors on my truck. One mirror pulls out with a little force, my other won't budge. My truck rocks when I pull on it. Any advice on how to free it up?
  2. Mar 15, 2020 at 4:52 PM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Looks OEM like mine. Maybe some sand and grit in there creating friction
  3. Mar 15, 2020 at 4:52 PM
    Red Freighter
    Red Freighter Red Freighter
    Oregon City
    2013 double cab sr5 trd red
    2014 TRD wheels and TRd pro center caps. Stock 2014 running boards. Stereo gps dvd deck two 12" subs w/amp. Dvd Headrests. Rear air bags with compressor and air tank.
    You could try some WD40.
  4. Mar 16, 2020 at 5:11 AM
    New2TundraTRD
    Adrian
    Ontario
    Tried it. Is there anyway of getting inside or the top cap closest to the truck? Without breaking it
  5. Mar 16, 2020 at 5:18 AM
    mtTundra
    mtTundra New Member
    Bozeman MT
    2016 Platinum 4X4, 1997 Tacoma 4x4
    Longer list than the wife needs to know about....
    You could try unbolting the mirror from the truck, that might give you access to the internals? should be 3 bolts behind the door panel.
    *Disclaimer I don't have those mirrors so I don't know if this would give you any additional access its just a thought.
    Lake.Life24 likes this.
  6. Mar 16, 2020 at 5:42 AM
    Mnorris1206
    08 tundra
  7. Mar 16, 2020 at 1:21 PM
    New2TundraTRD
    Adrian
    Ontario
    I had the door panel off yesterday to replace my door check. Should of looked. It's quite easy to pull it off. I will have another go at it
  8. Mar 16, 2020 at 1:32 PM
    Pyrite Tundy
    Pyrite Tundy New Member
    I removed the endcap in between the arms and shot some lubricant onto the slides, that worked for me.
  9. Mar 16, 2020 at 4:28 PM
    New2TundraTRD
    Adrian
    Ontario
    Do have a picture for me so I don't go cranking on something and break it?
  10. Mar 16, 2020 at 5:00 PM
    Pyrite Tundy
    Sorry should have been more descriptive.
    The cap inside the red circle, squeeze the area in yellow also the frontside of the same cap. You can use a screw driver but will most likely scar up the surrounds.
    You will have two slides that are housed in the extendable portions, spray with lubricant.
    That should free up the slides.
  11. Mar 17, 2020 at 6:14 AM
    New2TundraTRD
    Adrian
    Ontario
    Thank you very much P
  12. Mar 18, 2020 at 4:14 AM
    awq735
    awq735 New Member
    Anthony
    Ohio
    2019 Tundra Sport, MGM
    I would recommend silicone spray lube. It goes on wet and leaves a dry film that wont attract more dirt/grime into that area, and its waterproof
  13. Mar 18, 2020 at 7:49 AM
    New2TundraTRD
    Adrian
    Ontario
    So I took the mirror off, sprayed the shit out of it with better than WD-40, and you would think that would of loosened it up???? Nope. Warmer weather is coming and I will remove it completely and take to the work bench and see what I can do. Thanks to all for the help.
    P.S. stilll haven't gotten my decal. Lol
