Exploding fan
Discussion in '2nd Gen Tundras (2007-2013)' started by Sabby71, Feb 23, 2025.
  1. Feb 23, 2025 at 4:57 PM
    Sabby71
    Sabby71 [OP] New Member
    2007 tundra SR5
    Has anyone ever heard of the fan blade just exploding for no apparent reason? Mine has done it twice within six months.
  2. Feb 23, 2025 at 5:31 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Never really heard about this problem before on this forum, but plastic does deteriorate over time. Was the second fan it happened to new or used?
  3. Feb 26, 2025 at 7:05 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Does/did the fan seem to make a lot for noise than before?
    You may have a bad fan clutch attempting to run at warp speed all the time.
    Old BMWs are known to do this when the fan clutch fails, and can unleash all kinds of carnage.
    Also, use OE parts if at all possible.
  4. Feb 26, 2025 at 8:45 AM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    I'd say check your fan clutch, check your radiator mounts, check your shroud mounts, and check engine mounts.
    Either the fans were old and spun fast enough to cause the blades to separate, or something is causing the blades to hit the shroud.
    If the fan clutch is seized, it will cause stress on the blades when it is running full bore and when the engine shuts off.
    landphil likes this.
  5. Feb 26, 2025 at 9:03 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    I've had my drive belt strip and wrap around my fan a couple of times, but never exploded.. water pump has twice.
  6. Feb 27, 2025 at 7:28 AM
    Sabby71
    2007 tundra SR5
    I
  7. Feb 27, 2025 at 7:29 AM
    Sabby71
    2007 tundra SR5
    It was new(about 3-4 months old).
