Experience with Rotopax???
Discussion in '2.5 Gen Tundras (2014-2021)' started by HighonFirewood, Jan 27, 2020.
  1. Jan 27, 2020 at 8:13 PM
    HighonFirewood
    HighonFirewood [OP] Everything can be fixed with a hammer.
    Stage Left. Colorado
    2019 Tundra
    Anyone have experience with various sizes? I plan to get 2 - 2g or a 4 gallon rotopax. Is the 4 gallon cumbersome and a PITA? I am planning mainly for my boat on road trips..but would come in handy out in the bush too. The 4g looks a little odd handle.
  2. Jan 27, 2020 at 8:37 PM
    71_340
    71_340 The German
    Hans
    FLW, MO
    You might want to consider a regular 5 gal old school jerry can and the mount for it. Definitely a proven design, the military still uses it and those trucks are apt to operate in much harsher environments then your Tundra ever will.
  3. Jan 27, 2020 at 8:57 PM
    airosey
    airosey 2009 CrewMax Limited 4x4
    East TN
    Slightly modified 2009 CrewMax Limited 4x4
    09 Tundra CrewMax Limited TRD Supercharger with URD pulley Tuned by OrangeVirus tuning (OV Tune) TRD Big Brake Kit with SS lines and titanium backing plates StopTech rear sport axle pack (rotors, pads, and SS lines) 7” Pro Comp lift 3” Performance Products Body Lift Coachbuilder 1” coilover shims Coachbuilder +3 shackles Coachbuilder Tie-rod ends 22x14 -70 Fuel Lethal’s - 2 piece 38x15.5 Mickey Thompson Baja Boss M/T’s King Shocks with remote reservoirs front and rear Nitro 5.29 gears front and rear Auburn LSD SPC adjustable UCA’s BAM 8” exhaust Pro Comp Traction Bars Enve Grille Smittybilt M1 front bumper Rough Country 12k lbs winch Demon Hook shackles front and rear Baja Designs Squadron Sport Amber and clear fog lights ADD HoneyBadger Rear Bumper with Rigid SR-Q reverse lights Sequoia Headlight conversion Switch-Pros SP-9100 mounted in overhead console SD Off-road MT under-hood tray AEM boost and afr gauges Hypertech Speedometer calibrator Bed and rear bumper are Bulletlined American Flag Headliner Mammoth Guards patriot edition Alpha and Omega Fabrication Patriot Hood shield 3rd gen door panels and steering wheel ProSpeed Catchcan Hornblasters Outlaw train horns Tufskinz real carbon fiber overlays Tufskinz carbon fiber B panels vLEDs footwell lighting front and rear vLED puddle lamps Lighting Trendz flow series wheel rings 16 RGB rock lights Toyota Bedmat Bestop Power folding steps Undercover bed cover Undercover SwingCase 4 gallon Rotopax fuel can Here’s a rundown of the audio setup. -Active front stage using a JL Audio TwK88 DSP, Focal 165KRX2 component speakers, powered by a JL Audio HD900/5 -Passive rear setup with Focal 165KRX2 component speakers -2 JL Audio Stealthboxes (13TW5’s) powered by a JL Audio HD1200/1 -Sony XAV-9500ES float mount display with a PAC Radio Pro 4 -Odyssey battery -JL 0 gauge power and ground cables -AudioQuest X-2 speaker cables and Golden Gate RCA interconnects -Entire cab has been lined with Dynamat Extreme and 1/4 CCF Amps and dsp are mounted under the passenger seat with a SoundsGoodStereo mounting plate.
    I love mine. I have a 2gal water and a 2gal fuel on the RZR, then a 4 gal in the Tundra just for an oh shit moment. Had them for over 2 years and none of them have ever leaked.
  4. Jan 27, 2020 at 9:34 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
  5. Jan 27, 2020 at 9:36 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Spend 1/4 the price and get something with more capacity and not some weird awkward overlander mallcrawler blingy stuff that takes 5 days to pour due to the California nozzle.
  6. Jan 27, 2020 at 9:43 PM
    TheBeast The Beach
    that's what I carry in my bed.
    HighonFirewood[OP] likes this.
  7. Jan 27, 2020 at 9:46 PM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    Totally not worth it and they suck at pouring. Just use a a racing fuel jug or a normal jerry can.
  8. Jan 27, 2020 at 11:17 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Damn, am i the only one with one that pours just fine? I have the 3 gallon one. Biggest complaint is too much flex in plastic. Needs vented way to much in my opinion. Otherwise its held up great so far. Just under a year of use.
  9. Jan 27, 2020 at 11:26 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
  10. Jan 28, 2020 at 4:11 AM
    Theonlyway
    Theonlyway New Member
    User
    I never got to experience using it because the rotopax mount and lock were awful to deal with.
    Sunnier likes this.
  11. Jan 28, 2020 at 5:25 AM
    HighonFirewood
    2019 Tundra
    I failed to mention, this is to keep on my roof rack. I have a classic 5 gallon fuel jug now. I just have to move it all over the place in my bed (always in the way). I’m not excited about daily venting on a trip either.
    jewsNbrews likes this.
  12. Jan 28, 2020 at 5:29 AM
    HighonFirewood
    2019 Tundra
    I’ve seen your truck over time and what you’ve done to it is awesome.
    Spvrtan[QUOTED] likes this.
  13. Jan 28, 2020 at 7:08 AM
    InTheRough
    InTheRough New Member
    Kolt
    Gig Harbor, Washington
    2020 Platinum
    AR Headers DirtyDeeds Exhaust UpTop Racks Rock Warrior wheels
    I had 2x 2-gallon fuel cans as well as 1x 2-gallon water and 1x storage container all deal together with the upgraded metal clips. I liked having the 2x 2-gallon vs the 4-gallon as I was able to judge quantity better; use two gallons or use all four gallons.
    I built fiberglass mounts for the Rotopax on my Tacoma and thought they were an awesome purchase until the lock cores seized up - due to cheap steel internals - and I couldn't get the fuel cans off when I needed them. The same thing happened to the lock cores holding the storage can... I couldn't get to any of my shackles until I drilled the lock cores out.
    Rotopax replaced my lock cores twice before I stopped relying on them to work. I just removed the lock handle and hoped no one would steal my stuff.
    As far as the cans themselves, they were ok. They were convenient at times but two of my locking pour spouts broke; the 'lock' twist/slide spring broke off.
    I'd still considering buying them again if they worked out the bugs.
    HighonFirewood[OP] and airosey like this.
  14. Jan 28, 2020 at 7:38 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    I had 2 of the 2 gallon models, the seam on one ended up with a small crack in it and leaked all over.
    They replaced it, so good customer service.
    I just didn’t like the spouts, they never seemed to seal well.
    I damaged a gasket on one, so you have to be somewhat careful when tightening it up.
    The other thing that I didn’t like is how the spout was designed, being inverted and in the gas means when you need to use you have to pull it out of the gas and turn it around, plan on smelling like gas if you need to fill anything up.
    I went back to a 5 gallon Tuff Jug.
