Expanded or Aux fuel tank for 1st gen tundras?
Discussion in '1st Gen Tundras (2000-2006)' started by SSgtMack, Mar 28, 2020.
  1. Mar 28, 2020 at 9:33 AM
    SSgtMack
    SSgtMack [OP] I escaped communism; I used to live in California.
    2003 Tundra SR5, iForce V8
    Blue Lake Off Road custom front bumper, custom injectors, custom exhaust from Dirty Deeds Industries, Spec-D Tuning cold air snorkel intake, Optima Yellow Top, Smitty Bilt cable winch, A.R.E. camper shell, homemade steel rear bumper, Rigid Industries 20" spot/flood combo light bar
    Same problem we always have with 1st gen tundras: Finding someone who makes aftermarket parts to upgrade with.... this time I'm trying to find someone who makes an larger/expeditionary fuel tank to replace my factory fuel cell. I've seen some for 2nd and 3rd gen tundras (Transferflow), but yet again, nothing for 1st gen's. Any suggestions from the crowd??? I've read a lot of discussions about home-shop projects fitting cannibalized tanks that are small enough to fit under the bed where the factory spare tire would normally go and using that as an auxiliary tank, but obviously that involves creating a whole other fuel port and most of those aux tanks feed/pump directly into the main fuel cell, not directly to the engine, plus I'd rather just have one larger cell. I have an incredible amount of spare room under the bed behind the axle since my spare tire and exhaust tips are no longer located back there, so IDEALLY I would much rather just swap out my factory tank for one that expands towards the center and rear of the vehicle (I could easily fit another 50 gallons under there before I'd had to start worrying about weight/balance). If anybody has cannibalized something like this that fits under our trucks, that would be awesome to hear about...
    2003 Toyota Tundra SR5, iForce V8
    Dirty Deeds Industries custom exhaust terminates in front of rear right tire.
    Seck44 and speedtre like this.
  2. Mar 28, 2020 at 1:05 PM
    imDementeD
    imDementeD New Member
    2003 Tundra Limited 4x4 Trd Supercharger
    I've done quite a bit of searching and there's definitely nothing that is a "bolt-on".
    Not sure who's going to be the first to figure it out but the best case is finding something close and modifying to work.
    theblurry1 likes this.
  3. Mar 28, 2020 at 11:41 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    i believe the only route thats really out there would be having a custom fuel cell made.. but packaging may end up making it smaller than the OEM because of the shape of the OEM tank utilizing space pretty efficiently
  4. Apr 12, 2020 at 5:22 PM
    BLUEMIDGET
    BLUEMIDGET New Member
    BOZ
    2004 4DR TUNDRA 4WD
    NERF BARS, WINDOW TINT , BED COVER
    '' most of those aux tanks feed/pump directly into the main fuel cell, not directly to the engine, plus I'd rather just have one larger cell.'' FYI...that is NOT the way Most Aux Tanks work...sounds like maybe you are thinking about Transfer Tanks , like you would mount in the bed of your truck ! If you add a 2nd tank and have it set up right....with the flip of a/one switch or toggle your new fuel pump will switch which tank it is pulling fuel out of , if your engine is equipped with a return fuel line it will which tank the gas that was pumped to the engine but not used...back into the tank it was pumped out of and it will switch which sending unit your stock gas gauge is getting it's info from so that your gas gauge that was showing empty is now hopefully showing that your aux tank is FULL. So I can not help you on what aux tank will work on your Toyota but hopefully I shed some light on how it should work when you find it/one. I will check with my old tank suppler and if they offer anything that will fit I will let you know. Good luck BLUEMIDGET
