Exhaust
Discussion in 'Performance and Tuning' started by YOTA2015, Apr 28, 2016.
  1. Apr 28, 2016 at 5:11 AM
    YOTA2015
    YOTA2015 [OP] New Member
    Tyler
    2015 tundra sr double cab 2wd
    Stock
    Was looking at my truck exhaust and I see that there are 4 cats on it and the 02 sensors are in between the two on each side I was curious if I cut the back ones off would it throw a code or would it cause me to fail an emission test or would it be fine?
  2. Apr 28, 2016 at 6:15 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Pre cat measures your air fuel ratio and post cat measures catalyst efficiency ....so yes a code would be thrown
  3. Jun 9, 2016 at 3:15 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    won't throw a code, and unless you're in Commufornia you'd probably be fine with emissions.
    That said, it would only be for sound. There is no benefit to removing em.
    How many miles on your truck?
  4. Jun 9, 2016 at 3:29 PM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    My last car had 4 cats with 4 sensors, the rear 02 sensors were in front of the secondary cats. I replaced the secondary cats with test pipes and occasionally my check engine light would come on, I would just clear with my scanner. After the cat delete I noticed that my rpm's would rev faster and the acceleration of my higher speeds definitely improved.
