Exhaust
Discussion in 'Performance and Tuning' started by JJcksn12, Mar 19, 2025.
  1. Mar 19, 2025 at 9:05 PM
    JJcksn12
    JJcksn12 [OP] New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    Can anyone tell me why the exhaust on 3rd gen is exits out of the drivers side?
    I don’t know that I’ve ever noticed exhaust exiting the drivers side of any vehicle.
    probably don’t matter but I’m sure there is a reason?
  2. Mar 19, 2025 at 9:26 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    I could be wrong, but I think they moved the gas tank to the passenger side to get a more even 50/50 weight distribution split between left and right sides of the truck.
    The 2nd gen models are known for having a drivers side "lean" due to excessive weight on the drivers side, so I'm assuming they decided to try to fix it on the newer models.
    Moving the gas tank to the passenger side would require rerouting the exhaust, so that'd be my first guess :)
  3. Mar 19, 2025 at 9:28 PM
    JJcksn12
    Jay
    Never even crossed my mind. Thank you
  4. Mar 20, 2025 at 4:18 AM
    SilveradoSwap
    SilveradoSwap New Member
    2024 1794 Edition Tundra
    I have an AWE exhaust on order and realized the other day while cruising down the highway that when I am in the hammer lane that the exhaust will be pointed right at the concrete median, should make for some good exhaust sounds.
    JJcksn12[OP] likes this.
  5. Mar 21, 2025 at 7:50 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    The reason it’s on the driver side is to pass federal sound level requirements. The testing device is on the curb side of the vehicle during testing.
    1lowlife likes this.
  6. Mar 21, 2025 at 9:41 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    because that is how they designed the truck
  7. Mar 21, 2025 at 1:01 PM
    JJcksn12
    Jay
    your so alpha
    Soupbean77 and 1lowlife like this.
  8. Mar 21, 2025 at 5:29 PM
    SilveradoSwap
    JJcksn12[QUOTED][OP] likes this.
  9. Mar 21, 2025 at 5:34 PM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Not sure of the reason, but yes, gas tank on passenger side.
    Not enough room to route exhaust on the same side.
    JJcksn12[OP] and Soupbean77 like this.
  10. Mar 21, 2025 at 5:49 PM
    JJcksn12
    Jay
    Nothing, that was not directed at you.
  11. Mar 21, 2025 at 5:56 PM
    Tunrod
    Tunrod New Member
    Rod
    2021 SR5 CM 4x4
    Fuel tank on passenger side and fuel door on drivers side?
  12. Mar 21, 2025 at 6:07 PM
    Soupbean77
    Soupbean77 New Member
    2023 Mag Grey Tundra Limited Crewmax 4x4
    As far as I’m aware most every, if not all Toyota’s have always had exhaust routing to the right or right rear of the vehicle. When I started shopping the 3rd gen Tundra, that’s something that caught my eye in regards to any Toyota I’ve owned in the last 40 years. As mentioned before, I believe it was something to do with the fuel tank placement as primary along with other components and the exhaust routing was of least concern.
  13. Mar 21, 2025 at 6:20 PM
    JJcksn12
    Jay
    Don’t make a shit to me I just thought it was weird. This is the first vehicle I’ve seen where it exits the drivers side.
    Tunrod likes this.
  14. Mar 21, 2025 at 6:40 PM
    BlackNBlu
    Rich
    MN
    Yep.
