Exhaust vapor
Discussion in '2.5 Gen Tundras (2014-2021)' started by TXRailRoadBandit73, Jul 28, 2016.
  1. Jul 28, 2016 at 1:20 PM
    TXRailRoadBandit73 [OP] YOTAS,RAILROADIN',RÖKnRÖLLN',BEER,MAX/GEMMA
    Was curious about my ride...is it bad that I don't see water coming out from exhaust ends??? Fairly new truck is this bad that I don't see any vapor come out???
  2. Jul 28, 2016 at 1:56 PM
    Right now it is probably too hot in TX. Usually you only see water vapor during cold starts and after the vehicle warms up, the water turns to steam coming out of the exhaust.
    This is a natural occurrence during the combustion process.
    T-Rex266 likes this.
  3. Jul 28, 2016 at 3:27 PM
    Mike Tread lightly.
    south carolina
    The platinum in the cats are new so you will not see vapor. Over time as the platinum starts to get worn/plugged up over time you will noticed some.. but honestly don't worry about it..
    Water is the platinum conversion from bad gasses to water it's a anvil used in water heaters for example. Its Sacrificial in away..
