Exhaust Leak, Header Options
Discussion in '1st Gen Tundras (2000-2006)' started by Limited Time Only, Jun 23, 2023.
  1. Jun 23, 2023 at 9:16 AM
    Limited Time Only
    Limited Time Only [OP] New Member
    Kyler
    2003 Limited Tundra 2WD Access Cab Stepside
    Hey guys, first post here. I recently bought an ‘03 access cab with the 4.7. I believe the truck has an exhaust leak so I’ve been looking at some aftermarket headers. Most threads I looked through could be summed up by saying “long tubes or bust”. Looks like I missed the boat on long tubes by a couple years though. So I guess my options are basically JBA or Doug Thorley short tubes, or just replace with stock manifolds. Are the short tubes at all worth the headache of installation or would I be better off staying stock? Any advice on which direction I should go (or if anyone knows where to find a nice set of long tubes) would be greatly appreciated.
  2. Jun 23, 2023 at 9:59 AM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I did long tubes and dual exhaust a little over a year ago. power increase is real, around 1.3 seconds off 0-60.
    however if I could go back I'd probably just replace the stock manifolds. Mainly due to exhaust note/drone when I'm towing the camper.
    It was enough of a pain just doing long tubes that I personally wouldn't want to mess with the extra bulk of shorty's,
    YMMV
    shifty` and Casper421 like this.
  3. Jun 23, 2023 at 10:24 AM
    Limited Time Only
    Kyler
    Thanks for your input! I didn’t realize shorty’s would be more difficult to install than long tubes. Also I don’t mind some extra noise, my previous vehicle was a 7.3 Ford Diesel that I had to shut off at drive-thrus. I can barely hear this truck running with my radio on at medium volume.
  4. Jun 23, 2023 at 11:49 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I don't think anyone makes long tubes anymore sadly.
    Have you inspected or replaced your steering shaft seal yet? A lot of us have done that and it helps reduce that exhaust tick considerably.
    See this thread.
    https://www.tundras.com/threads/diy-steering-shaft-seal.48664/
    If you are still dead set on replacing your manifolds I would go with short tubes. The job sucks either way but you might as well get something out of it. The gains aren't huge but better than stock manifolds.
    N84434 and FrenchToasty like this.
  5. Jun 23, 2023 at 1:39 PM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
    I don't have much to add other than, I got the Doug Thorley headers, they are very nice, and I paid a custom exhaust shop to install them because there was no f'ing way I'm attempting that job in my driveway.
  6. Jun 23, 2023 at 3:24 PM
    TX-TRD1stGEN
    TX-TRD1stGEN Privileged
    Seth
    South East Texas
    2000 Tundra 4x4
    I installed jba short. No increase in noise vs stock. fixed my exhaust leak.
    Install wasn’t as bad as everyone makes it seem. It’s no harder than swapping for stock manifold.
    Unbolting the motor mount to raise and lower the engine a few inches helped a bit
  7. Jun 23, 2023 at 3:27 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    Installing headers is a lot easier if you remove the engine mount from whichever side you're working on.
    You can accomplish this by either the accross-the-fender engine support stand (around $80-100 from Scamazon and Hobo Freight), or you can support the oil pan flange on the side of the engine you're working on with a jack and a 2x4 piece of wood.
    I did long tubes but swapping in shortys would be on par, difficulty wise, as changing factory manifolds. The biggest power booster on these engines come from changing the manifolds to a better tuned, better flowing piece.
    Two birds one stone. If your steering shaft grommet isn't the culprit, you can get more power and get rid of the cracked manifolds.
    Use factory studs and a good MLS manifold gasket with new headers to prevent leaks.
  8. Jun 23, 2023 at 5:46 PM
    Limited Time Only
    Kyler
    How long ago was that and what did they charge? Curious if this could be an option for me
  9. Jun 23, 2023 at 5:55 PM
    Limited Time Only
    Kyler
    Thanks for the advice! Is there a good thread or youtube video with step-by-step instructions for removal and install?
  10. Jun 24, 2023 at 12:45 PM
    Riverdale21
    OTP ATL
    There is. https://youtu.be/LKy_y5x-pmM
    There's more too. Just search "Toyota 2uz header install".
  11. Jun 26, 2023 at 8:21 AM
    Mustanley
    Hendersonville, NC
    2 and 1/2 years ago. $900 covered about 8 to 10 hours of labor, new studs and locking nuts and welding the new lower header flanges, new spintech muffler and dual exhaust from the muffler out the back.
